Overdrive override?
Discussion in '5th Gen 4Runners (2010-2024)' started by MountainMan, Aug 21, 2019.
  1. Aug 21, 2019 at 12:25 PM
    MountainMan
    MountainMan [OP] New Member
    Pacific Northwest
    My 2005 Yukon had a Tow Mode button that I would engage that basically held the shift points longer and kept the transmission out of overdrive. Was great for towing.
    I did a search on the forum and online and haven't found any reference to any such feature on the 2019 4Runners. Do they have and OD override button? Or do I just have to shift it over to the "S" mode and manually shift it?
  2. Aug 21, 2019 at 1:25 PM
    Dillusion New Member
    KYle
    Manually shift.
  3. Aug 21, 2019 at 4:16 PM
    Backwoods
    Backwoods New Member
    2019 silver SR5 4x4
    I kind of miss that ECT button on the Tacoma. I used it when towing... And when i wanted to pass someone LOL
    WallyT4R likes this.
  4. Aug 21, 2019 at 4:31 PM
    4runningMan
    4runningMan New Member
    New Mexico
    You'll want to bump it over to S-mode and drive in D4.
    S-modes are nothing more than a gear limiter. You can shift on the fly. Just tap it wherever you want it.
    I think the torque converter is removed from the equation in S3 and S4.
  5. Aug 21, 2019 at 4:32 PM
    4Runner fun
    Ryan
    Nebraska
    Shift into Manual mode.
    It will say 4th gear. It is not in 4th gear.
    It is in first gear. Listen to the shifts.
    Using manual mode locks out 5th gear (thus the 4th gear reading). You can manually shift to 5th if the terrain is conducive.
    This is basically your O/D off button. Not sure if it locks the T/C as in some "tow" modes.
    Hope it helps.
    Please advise if I missed something.
  6. Aug 21, 2019 at 4:53 PM
    4Runner fun
    Ryan
    Nebraska
    P.S. you may downshift to help engine brake & bring it all down quicker.
    It will not upshift in this mode. You must upshift to the appropriate gear.
    It is almost a 4 spd manual except it holds the gear as you slow down.
  7. Aug 21, 2019 at 5:12 PM
    MountainMan
    Pacific Northwest
    Thanks all!
    4Runner fun likes this.
  8. Aug 21, 2019 at 5:55 PM
    Agent_Outside
    Built 2011 T4R Limited
    It’s not manual mode, you are not shifting the trans, it’s still shifting when and where it wants your just choosing the highest gear it can upshift into.
    a47chuck, WallyT4R and SlvrSlug like this.
  9. Aug 21, 2019 at 6:10 PM
    KYle
    I bet I can make it shift to 4th while riding in 3 going 60+ :)
  10. Aug 21, 2019 at 6:57 PM
    BananaWagon
    BananaWagon Highly Caffeinated
    Ray
    Nomad
    2019 Black TRD Off-Road
    None.... Yet.
    Correct. I have been doing this while pulling my trailer for the last 5k miles.
  11. Aug 21, 2019 at 7:01 PM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    This graph is a little vague, but kind of explains converter lock out. I don't tow, but I do know when mine is loaded down at hwy speeds and hit a steep grade, then shift over to S4 the trans goes to 4th with no lock up. The lock up will kick back in while still in 4th after the given load going uphill, rpms, and speed match up to the ECU parameters. I think lock up will disengage to help with braking on a downgrade but not entirely sure how that operation works though. Maybe someone with more knowledge will chime in.
    a47chuck likes this.
