Overall gearing ratios versus crawl control
Discussion in '5th Gen 4Runners (2010-2024)' started by Yoytota, Jun 28, 2022.
factory 1st gear 4 low
  1. True Crawl Gear 95:1 1st gear 4low with no crawl control
  2. Crawl control with 39:1 overall ratio in 1st gear 4 low
Results are only viewable after voting.
  1. Jun 28, 2022 at 7:23 AM
    Yoytota
    Yoytota [OP] New Member
    FL
    SR5 4X4
  2. Jun 28, 2022 at 7:24 AM
    Yoytota
    FL
    SR5 4X4
    Sorry but I don't get it
  3. Jun 28, 2022 at 7:29 AM
    Yoytota
    FL
    SR5 4X4
    Enough with the crawl control nonsense. Give me the true granny gear. I basically want to be able to pull stumps idling in first gear lol
  4. Jun 28, 2022 at 8:48 AM
    Haha. Remember before you got your 4Runner you watched a hundred videos on YouTube that demonstrated how capable the 4Runner is? And then you got one? Don’t get hung up on the numbers. :)
    brownersd, Ironguy, Saker and 4 others like this.
  5. Jun 28, 2022 at 9:22 AM
    dougfresh
    dougfresh New Member
    Doug
    Las Vegas, NV
    '22 ORP, '19 Mustang GT, '69 Z/28 Camaro
    This thread is very 'the last breed'
    brownersd, 2Toys, icyhotahs and 3 others like this.
  6. Jun 28, 2022 at 9:31 AM
    Yoytota
    FL
    SR5 4X4
    these numbers arent meant to be a bad thing they mean that your Toyota drivetrain should last way longer than the others by reducing stress and strain on all of the pieces and parts in between the engine and the wheels
    brownersd and BionicRandy like this.
  7. Jun 28, 2022 at 9:37 AM
    Yoytota
    FL
    SR5 4X4
    I'd like to see a better balance in between gearing and longevity in Toyota trucks and SUVs but most folks that put longevity up at the top of the list right off
    brownersd likes this.
  8. Jun 28, 2022 at 9:39 AM
    I do agree, to an extent. I think the granny gears are part of Toyota's way of getting reasonable gas mileage. But, I'd rather have a transmission with more gears, and 4:10's.
    I also wish 4lo had more gear reduction. Maybe the next generation will have a super low first gear.
    As far as Crawl control; I would gladly trade that for a front locker. :)
  9. Jun 28, 2022 at 9:41 AM
    Yoytota
    FL
    SR5 4X4
    Also my color choices were bad in the tables I was trying to show Numbers high to low
  10. Jun 28, 2022 at 10:04 AM
    Notice how the higher ratio options have more gears? The Runner could use another gear or 2 but it's fine as is.
  11. Jun 28, 2022 at 10:11 AM
    Yeah lets compare a vehicle that hasn't been updated in forever vs ones that have been.
    Make perfect sense.
  12. Jun 28, 2022 at 10:14 AM
    Yoytota
    FL
    SR5 4X4
    Toyota isn't making their gearing ratios any higher on the new gens. Based on what we've seen in the new tundra and Sequoia anyways
  13. Jun 28, 2022 at 10:31 AM
    GodOfDirt
    GodOfDirt New Member
    STL, MO
    2019 Magnetic Gray ORP
    GOBI Ranger & Ladder RSG Flat Rails WeBoost Cell Amp
    To get lower gear ratios, you have to either increase the driven gear (bigger diff's - reduced clearance) or shrink the driver (smaller pinions - less engaged teeth).
  14. Jun 28, 2022 at 10:36 AM
    Did you you mean "lower"? On the differential higher number = lower gearing.
  15. Jun 28, 2022 at 10:38 AM
  16. Jun 28, 2022 at 10:40 AM
    Yoytota
    FL
    SR5 4X4
  17. Jun 28, 2022 at 10:46 AM
  18. Jun 28, 2022 at 10:49 AM
    Bikeric
    Bikeric New Member
    Eric
    2003 V8 4x4 ARB Locked and Lifted on 35's with 4.88's
    My 1984 with manual and 5.29 gears calculates to be a 49.33 crawl ratio. It's kind of amazing that a new manual Bronco Sasquatch is nearly double that, BUT.... look at the Bronco's puny driveshafts and think again about calling the Toyota drivetrain weak. o_O:)
    2022 Ford Bronco rear driveshaft coming out of transmission.
    2022 Ford Bronco front driveshaft I can wrap my fingers around it.
    brownersd, 2Toys, GrantA and 3 others like this.
  19. Jun 28, 2022 at 10:54 AM
    GodOfDirt
    STL, MO
    Thanks, fixed. need more coffee.
  20. Jun 28, 2022 at 10:55 AM
    Not sure why people look at the rear end #'s and consider it bad. I'm not engineer nor have I watched anything comparing it with the other trucks. But I'm sure there is a reason.
    I don't think Toyota had plans to make a serious "off roading" vehicle like we would wish.
  21. Jun 28, 2022 at 11:04 AM
    It just seems to be a typical thing to discuss. And, it's the only one we can really change down the road.
    Our 3.73's are fine at stock. But, add a bunch of weight and oversized tires, and many people end up regearing.
    I will eventually regear if I end up keeping this as long as I planned. Unfortunately, the most readily available regears are too aggressive for what I would want. But, if I end up with 35's, I'll be all about a 4.56 or 4.88.
  22. Jun 28, 2022 at 11:09 AM
    Most likely the smaller diameter section is solid while the larger diameter section is hollow. Diameter alone isn't much of a sign of weakness.
  23. Jun 28, 2022 at 11:14 AM
    I think it's like the old Tacoma rear drum vs disc argument.
  24. Jun 28, 2022 at 12:16 PM
    Yoytota
    FL
    SR5 4X4
    I'm interested to see if Crawl control beats true crawl gear in the survey. Folks probably prefer a simulated crawl gear instead of an actual crawl gear
  25. Jun 28, 2022 at 12:30 PM
    Mall control just controls throttle and braking to move at a selected speed and uses traction control to put power where there's traction. There's no change in gearing besides simply being in low range.
    Captain Spalding and Thatbassguy like this.
  26. Jun 28, 2022 at 1:11 PM
    Yoytota
    FL
    SR5 4X4
    I'm wondering if Toyota said let's just leave the overall gear ratios lower in 4low to make the drivetrain last longer and then just add on electronic crawl control for the folks that want to rock crawl
  27. Jun 28, 2022 at 1:48 PM
    Personally I don’t consider our 5th gens as “rock crawlers”. I’ve been off roading Toyota’s for over 20 years and never had a problem, and that’s with no lockers, just basic 4wd.
    ecoterragaia likes this.
  28. Jun 28, 2022 at 2:02 PM
    Yoytota
    FL
    SR5 4X4
    What was the overall ratio in first gear 4 low of the last 4Runner manual transmission?
  29. Jun 28, 2022 at 2:32 PM
    I see 3.830 for 1st and 2.566 for low. The 3.4 only made 183hp and 217tq. The 5th gen is 270/278.
  30. Jun 28, 2022 at 3:46 PM
    Yoytota
    FL
    SR5 4X4
    Folks on the Tacoma website we're saying that the lower gearing ratios are actually worse for the drivetrain and performance and that it's basically all for EPA purposes
