On the fence between a Westcott Design lift and Eibach spring lift
Discussion in '5th Gen 4Runners (2010-2024)' started by Juan2022, Nov 2, 2022.
  1. Nov 2, 2022 at 11:44 AM
    Juan2022
    Juan2022 [OP] New Member
    Juan
    RGV
    2022 4 Runner TRD Pro
    None
    On the fence between a Westcott Design lift and Eibach spring lift on my 4R.
  2. Nov 2, 2022 at 11:48 AM
    Mtbpsych
    Mtbpsych New Member
    You bought a pro, why take out one of the things that makes it a pro? Makes no sense to me when people do that.
  3. Nov 2, 2022 at 11:56 AM
    You're pretty much stuck with a spacer lift unless you un pro bro your pro bro.
  4. Nov 2, 2022 at 12:05 PM
    Juan2022
    Juan
    RGV
    None
    Wanna mount some 33’s.
    kolter45 likes this.
  5. Nov 2, 2022 at 12:06 PM
    kmeeg LionRunner
    Me personally if I were to lift the Pro I would go with the suspension setup that is meant to be lifted from the start.
    If I ever have to use stock suspension (very unlikely) I would go with the Eibach spring lift but its not available for 2021 and up. I don't think I would go with spacer type lift removing the existing collar. Not sure the reason they use one spacer on top of the strut another one (the bigger collar) to preload the spring in front. Rear is a spacer for spring which still I don't know if stock shock is ready for extra length. Again I'm just dumb on this subject and its just my view as a regular user.
    Edit -
    I have to re-think about the lift as if I lift it might not fit through my garage door with the tall roof rack. My other 4Runners didn't have problems are they have regular roof rails. So my lift may not happen any time soon. Also read my concern about the wheel below. (Just sharing my opinion as a Pro owner)
  6. Nov 2, 2022 at 12:12 PM
    kmeeg LionRunner
    I wonder if you are thinking about 285/70R17 which is not recommend to mount on TRD Pro wheels by tire manufacturers due to narrow wheel width. I don't like to go 255/80R17 as they are Load E and I have bad experience with Load E when it comes to comfort in the past.
    BUT there are plenty of people running 285/70R17 on TRD Pro wheels.
  7. Nov 2, 2022 at 12:16 PM
    Juan2022
    Juan
    RGV
    None
    Yes, some MT’s,
  8. Nov 2, 2022 at 12:40 PM
    PJSnow
    PJSnow New Member
    PJ
    New York
    2018 Cavalry Blue TRD Pro
    I'll throw one more option into the mix, the Toytec TRD Pro kit ( ).
    There are plenty of forum members here who will bash on the collar kits or spacers but everyone's needs are different. If you have determined that a collar kit works for your needs, then you can't go wrong with any of them. Ultimately, I think the price will have a big part in the decision.
    Just a note, Black Friday sales are approaching so it may be wise to wait a few weeks.
  9. Nov 2, 2022 at 12:48 PM
    Juan2022
    Juan
    RGV
    None
    I didn’t know toytec had that kit.
  10. Nov 2, 2022 at 1:18 PM
    Lockdown
    Lockdown New Member
    Los Angeles
    2023 ORP Lunar Rock
    Jesus @Mtbpsych with no regard for mankind.
  11. Nov 2, 2022 at 1:24 PM
    Juan2022
    Juan
    RGV
    None
    So is the toytec better kit than the WD?
  12. Nov 2, 2022 at 1:33 PM
    Wescott and be done. Cheap and faster too.
  13. Nov 2, 2022 at 2:08 PM
    Juan2022
    Juan
    RGV
    None
    Is that what you did?
  14. Nov 2, 2022 at 3:23 PM
    Kilo Papa
    Kilo Papa New Member
    TX & NM
    2021 TRD Pro
    I’m one of these^^^^
    ‘21 Pro with OEM Pro wheels and Toyo 285’s with the Westcott lift.
    As Kmeeg says, the Eibach springs are not (yet?) available for ‘21’s and up so, unless you want to rip the Fox susp outta the Pro and do over, Westcott is about it. BTW, clearance for 285’s is fine with minor front wheel well fender trim and adequate forward caster.
    Contrary to some who dislike it, (many of whom are not Pro owners, so have no first hand experience), mine did exactly what I wanted and I’m happy with the Westcott solution. Note, I am not a big time rock crawler. We mostly do forest roads, sand, mud etc.
    Dir4219 and semprenissart like this.
  15. Nov 2, 2022 at 3:25 PM
    Juan2022
    Juan
    RGV
    None
    Thanks for your input.
  16. Nov 2, 2022 at 6:58 PM
    Yes, I started with wescott, a year later I put the Old man (Bp51) and I think it was ok, but maybe not needed. I am not a hard core off-roader, I'm a weekend warrior at best. So lesson learned, or not. I would much rather save the money for another mod and if you really want to change suspension do it later and go with something where you can really tell a difference. But of course, you will spend a lot! No free lunch here.
    Kilo Papa likes this.
  17. Nov 2, 2022 at 7:08 PM
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Solid advice.
  18. Nov 2, 2022 at 7:25 PM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    I went with the Eibach springs. It rode great and looked perfect.
  19. Nov 2, 2022 at 7:32 PM
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Sounds like a great solution for your SR5. Unfortunately, the Eibach springs are not available for the ‘21 and later Pros which is what the OP’s sig shows he owns.
  20. Nov 2, 2022 at 7:52 PM
    DallasTRDPro
    Dallas
    Well I did it on my ‘20 Pro.
  21. Nov 2, 2022 at 7:54 PM
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Right. As I said in my post, the issue is with the 21’s and newer Pros. Seems Toyota /Fox changed the front coilover spring seat on the Pros and Eibach hasn’t matched it yet.
  22. Nov 2, 2022 at 8:08 PM
    DallasTRDPro
    Dallas
    Well I don’t know how Eibach hasn’t come up with a solution. Then go with Westcott.
  23. Nov 2, 2022 at 8:21 PM
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Like you did on your ‘20, I wanted to use the Eibach springs for my ‘21. I thought it was THE solution. When I checked their website, they showed not available for front springs.
    I called them and was told about the glitch with the redesign of the front spring seats and was told they were “working on it” or something to that effect.
    I then went with Westcott’s kit which I’m happy with. They do what I want. I understand it might not be the best solution for others here.
    No solution yet from Eibach, to my knowledge.
  24. Nov 2, 2022 at 10:08 PM
    It’s a sign to leave it be. ;)
  25. Nov 3, 2022 at 9:16 AM
    Juan2022
    Juan
    RGV
    None
    Thanks for all the input fella’s, going to wait for retirement in 8 months, figure I’d save $$ on fuel with stock tires due to 40 min commute to work one way. Maybe by then the springs are out, if not WD it is.
    kmeeg likes this.
  26. Nov 3, 2022 at 9:27 AM
    Kilo Papa
    TX & NM
    2021 TRD Pro
    Sounds like a plan.
    Congrats on the pending retirement thing!
  27. Nov 3, 2022 at 9:29 AM
    Juan2022
    Juan
    RGV
    None
    Thanks
  28. Nov 3, 2022 at 9:53 AM
    Mr. Snuffleupagus
    Brandt
    2022 TRD Pro
    Elka 2.5 DC, Sherpa Crestone, C4 Lo Pro, Baja Designs S8, Morimoto 4bangers, Switch Pro 9100, Westcott Designs sliders, Toyo Open Country RT Trail 285 75/R17
    Im in the WD camp on my Pro running 285s on stock TRD rims- no problems. Stance is great, ride and nose dive are much improved and it keeps stock geometry. All in all a solid solution. Westcott is great to work with. One note of caution if you plan to continue building out your rig (steel bumper, winch, etc.) you might seriously just consider doing the suspension now as stock coilovers can not handle all that extra weight.
    LakeEffect likes this.
  29. Nov 3, 2022 at 10:20 AM
    I ran 285’s on my Pro rims with no issues. Came from the dealership that way.
  30. Nov 3, 2022 at 11:21 AM
    Juan2022
    Juan
    RGV
    None
    No plans for steel bumper nor winch.
