OME-BP-51 Suspension lift completed, Rebound and Compression settings input?
Discussion in '5th Gen 4Runners (2010-2024)' started by TST85, Feb 4, 2021.
  1. Feb 4, 2021 at 6:05 AM
    TST85
    TST85 [OP] New Member
    Tucker
    NH
    2020 TRD Premium Nautical Blue
    Off Road Package, 3" OME BP-51 Suspension Lift w/ OME upper control arms, OME 889 rear coils, Method MR315 17x8.5, Falken Wildpeak AT3W 285's
    Just finished having the OME bp-51 3" lift installed with new uppercontrol arms and rear coils alond with wheels and 285's....
    I'm working on dialing the Rebound and COmpression settings to my preferred settings, wondering if anyone is running this suspension and has any input from their experiences?
    Also, thinking of having the driver's side shimmed up to correct the 1/2" lean,,,wondering if its really necessary or if im just being OCD, also anyone installed shims themselves?
    *Side Note, I have ZERO rubbing issues which I was not expecting, I fully planned to have to remove the mudflaps at minimum.. 17x8.5 wheels w/0 offset & 285's9EE82EE0-FD54-40E0-A112-C318C522393A.jpg AF11FBD9-8991-46ED-8C65-0D31AE57FBA0.jpg FDFEAABC-1414-4C8A-A5A9-9075D46CCB36.jpg
    DrewMan, Joekader and HueyC like this.
  2. Feb 4, 2021 at 4:31 PM
    Joekader
    Joekader New Member
    Joe
    Love it
    I didn’t shim my truck I have about a 1/4 inch lean when or if I take out the suspension again you adjust the preload a few millimeters
    I think suspension feel is up to you I started at zero and went up I’m now running 4/3 all the way around
    Weight and tire choice will dictate your ride preferences
    My truck also has adjustable sway bar links and I now have an extremely tight ride and handling
    J
    DrewMan likes this.
  3. Feb 4, 2021 at 7:27 PM
    irfan0922
    irfan0922 New Member
    make sure your cv angle is straight you may need diff drop otherwise you will damage cv
    DrewMan likes this.
  4. Feb 5, 2021 at 8:05 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Aren't the BP-51 height-adjustable? Instead of adding a shim, simply raise the drivers side a bit with the adjustable collar.
    Hope you don't have any rubbing.. but your experience might change if you start flexing a little. Off-camber turns are the worst, especially in reverse.
    Definitely look into a differential drop, IMO.
    Truck looks good! Cheers.
  5. Feb 8, 2021 at 5:46 AM
    TST85
    Tucker
    NH
    Yes, I have installed a diff drop kit also, forgot to mention that
    irfan0922[QUOTED] likes this.
  6. Feb 8, 2021 at 5:49 AM
    TST85
    Tucker
    NH
    Thanks! I have found an angle in reverse where I have some rubbing, I will ultimately have to to a slight BMC because of where it rubs. I assume there will be more when I finally get it out in some rocks etc. We've had too much snow to really test it out since I had it installed, FOrgot to mention I have the diff drop installed already
    koukimonster[QUOTED] likes this.
  7. Feb 8, 2021 at 5:51 AM
    TST85
    Tucker
    NH
    ALso, thanks for the idea on adjusting the height with the collar..so obvious I hadn't considered it...i can be slow lol
  8. Mar 17, 2021 at 9:42 AM
    Calli74
    Calli74 New Member
    Tim
    @TST85 - Looks great. I'm in MA. Just picked up my 21 Off Road Premium - and starting to look at lifts as the factory suspension is too floaty for me. Where did you get this done? Care to share pricing? Overall experience so far? I was hoping to install something turn key w/no need for diff drops, etc. But probably inevitible. TIA! Pic for attention! :)
  9. Mar 17, 2021 at 9:56 AM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    Curious if anyone with the 4Runner BP-51 suspension has had any popping / dead strut noises like the TRD Pro FOX setups? I was reading about this issue with both the BP-51 (for other vehicles) and FOX internal bypass designs.
  10. Mar 17, 2021 at 6:55 PM
    Joekader
    Joekader New Member
    Joe
    I do on any temp under 30 but goes away the more I drive it’s not too pronounced I deal with it because the BP51 is phenomenal but I think my preload is a touch off
    koukimonster likes this.
  11. Mar 17, 2021 at 6:56 PM
    koukimonster
    koukimonster DYNO4
    Appalachia
    Midnight Venture
    I figured it wasn't actually a performance issue..
  12. May 1, 2022 at 6:04 AM
    Toyota.ARK
    Toyota.ARK New Member
    2021 Magnetic Gray TRD-ORP
    What settings did you end up settling on?
  13. May 7, 2022 at 9:01 AM
    I also added the Old man thing (BP 51) just yesterday......I went from stock to this OME - definitely a big difference from stock. I noticed a little vibration on the power steering around 40 to 50mph. The shop tells me they did a decent alignment - but I am not sure, maybe I need to break this in for a few days and see if everything settles.
  14. May 8, 2022 at 5:14 AM
    Joekader
    Joekader New Member
    Joe
    Enjoy them I do
