Oil Pan removal 1993 4WD
Discussion in '2nd Gen 4Runners (1990-1995)' started by pyee123, May 25, 2021.
  1. May 25, 2021 at 10:45 AM
    pyee123
    pyee123 [OP] New Member
    1993 4Runner SR5
    All, Have a leaky oil pan and I want to remove/reseal...I've heard that the "proper" way to remove the oil pan on these is remove the front diff and get at the pan that way. It looks like I can pull out the steering damper and linkage and pull out the Oil Pan that way. Am I correct?
    Also, there are two 10mm nuts at the transmission side of the pan that are obstructed by a cover. How do you get these out?
  2. May 25, 2021 at 8:27 PM
    pyee123
    1993 4Runner SR5
    UPDATE: OK, as I suspected there is more that enough room to pull out the oil pan from the front with the Steering linkage moved out of the way. I just can't find a wrench that can get to those nuts in the back. Even with a wobble extension and thin walled 10mm it won't fit. Especially the one on the driver's side... I have every nut/bolt out except for those two. (Maybe super long needle nose pliers?)
  3. May 26, 2021 at 7:25 AM
    bthp223
    bthp223 New Member
    Nevada
    1990 4X4
    Wow the original steering dampener, I’d be replacing that after your done. Otherwise I’m not much help but good luck you may have to make something.
  4. May 26, 2021 at 10:09 PM
    D60
    D60 New Member
    I honestly can't recall if the oil pump pickup will let you get the pan out, but you might be able to reach up in there and unbolt the pump blind/partially blind.
    It's best to have a new oil pump gasket.
    No help on the bolts as I had the tx out when I did it
  5. May 29, 2021 at 2:53 PM
    pyee123
    1993 4Runner SR5
    UPDATE: OK me being lazy, I didn't look around and there are 2 brackets on each side that when removed lets you remove the cover plate on the transmission and you can access thos 2 nuts....
    Now that I'm under here I figured I might as well inspect the connecting rod bearings... anyone have an idea of what size this nut is on the connecting rod cap? (I will probably only doe this once and I don't need another set of special wrenches) The Haynes manual is of no help with anything...
  6. May 29, 2021 at 3:06 PM
    pyee123
    1993 4Runner SR5
    OMG - Never mind. I'm stupid. It's a regular 12 point socket. I thought at first glance it was an eTorx...
  7. May 29, 2021 at 4:35 PM
    D60
    D60 New Member
    I forgot about the inspection cover. It was 100% MIA on the '93 I was working on
  8. Jun 25, 2023 at 3:03 PM
    Mike68
    Mike68 New Member
    Burgundy 4Runner
    Did you end up pulling the front differential. It doesn’t look like there’s enough clearance to pull the pan.
