Oil level - reading the dipstick
Discussion in 'General 4Runner Talk' started by redfield, Dec 7, 2022.
  1. Dec 7, 2022 at 6:08 PM
    redfield
    redfield [OP] New Member
    Apologizing in advance for stupid question
    I'm having a trouble interpreting my oil level results...
    Its seems the reading should be around point "A", but when Im looking close, I see the oil marks all the way up to point "B".
    Not sure if it's visible on photo...
    So, what is it - A or B?
  2. Dec 7, 2022 at 6:12 PM
    Jynarik
    Jynarik I like boobies
    Austin Texas
    2019 trd pro voodoo
    These dipsticks are a pain in the ass. 2 options:
    Leave the dipstick out overnight so you don’t have residuals.
    or if you change the oil, just put in your 6.6-6.7qts and never check the oil.
    suaveflooder and alittleoff like this.
  3. Dec 7, 2022 at 6:14 PM
    It's oil creeping up your dip stick tube.
    Take the dipstick out for 5 min. Put it back in and pull it out again to take an accurate reading.
    djwantke, MeefZah, 5thToy and 2 others like this.
  4. Dec 7, 2022 at 6:20 PM
    Singleminded
    Singleminded New Member
    2020 4Runner Limited
    OEM LED foglights
    As @Jynarik said, these dipsticks are a pain in the ass. And like @nimby said, the higher mark you see is oil creeping up the stick, not reflecting the amount of oil in the pan. So in your picture, it seems you are about 3/4 quart low.
    my method is to check the oil when the car is dead cold. Like in the morning. Pull it out, wipe it off and reinsert. I get consistent readings that way.
    the other thing I’d say is that if one side of the stick shows a lower level than the other, go by the lower level.
  5. Dec 7, 2022 at 6:39 PM
    alittleoff
    alittleoff New Member
    Steve
    406
    '16 TP
    Above are the best ways.
    I also park it, open the hood, pull the stick and check it in the morning.
    Or if you need to check it hot and you got 5-10 minutes, just pull it and wait a bit for the oil to drain from the tube.
  6. Dec 7, 2022 at 8:06 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    This. I have tried all the methods mentioned here. Wiping the stick clean and leaving it out for 5 minutes, allowing the tube to drain clear, then reinserting and pulling for measurement has been the most effective for me.
    This stick really is a pain to read. Especially with fresh oil. Darn near transparent.
    Rocko9999, nimby[QUOTED] and MeefZah like this.
  7. Dec 8, 2022 at 6:13 AM
    When I was a kid, I worked at a full service gas station and often checked oil.
    The Japanese cars always had the worst dipsticks. Always hard to read, and a lot of the times hard to find, because at the time they were just metal loops that blended in with everything else under the hood.
  8. Dec 8, 2022 at 8:46 PM
    suaveflooder
    suaveflooder New Member
    :cheers::cheers::cheers: Exactly what I do!
  9. Dec 10, 2022 at 6:52 PM
    redfield
    Ok, so, I took the dipstick out at night and the next morning - voilà, it's clean and readable :)
    Thank you all for advises!
    seakuv and PJSnow like this.
  10. Dec 11, 2022 at 8:34 AM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    PPF, Tint, Black out badges/Valances. Bilstein 6112's & 5100's
    And your low.
    BriGuy25 and PhantomTweak like this.
  11. Dec 29, 2022 at 5:26 AM
    TrailSpecial22 New Member
    PA
    Correct, you should be up to the B dot.
  12. Mar 25, 2024 at 1:25 PM
    Thrashpipe
    Thrashpipe New Member
    Hello, new to this dipstick. What does the 50/40 symbolize?
  13. Mar 25, 2024 at 1:33 PM
    Nevin
    Nevin New Member
    Puyallup, WA.
    2022 TRD ORP
    It actually reads 50140. Which is the second half of the part # 15301-50140
  14. Mar 25, 2024 at 1:36 PM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    I used some light sandpaper on the end of the dipstick, makes it much easier to read!
  15. Mar 25, 2024 at 1:37 PM
    Oakboro, N.C
    Part # of the dipstick.
  16. Mar 25, 2024 at 6:13 PM
    Thrashpipe
    Thanks guys! Sorry for such a noob question.
  17. Mar 26, 2024 at 3:54 PM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: LFD and Bud Built. Tires: KM3. Switchpro.
    When the oil is fresh and clear, you can carefully place the dipstick on a paper towel and slide it sideways to see the oil level on the towel.
    seakuv likes this.
