Oil filters
Discussion in '5th Gen 4Runners (2010-2024)' started by teddy4x4, Dec 25, 2024.
  1. Dec 25, 2024 at 8:56 AM
    teddy4x4
    teddy4x4 [OP] New Member
    24 SR5P
    I want to start changing the oil myself. Something about going to the dealership for oil
    Can anyone recommend an oil filter brand & stock number for a 2024 sr5
  2. Dec 25, 2024 at 9:18 AM
    Welcome to the forum.
    Oil type is a much discussed topic with many varying opinions. For the sake of conversation try searching and reviewing some of dozens of pages of prior posts regarding oil type and change interval. Just stick to a good synthetic of your determined choice and you will be perfectly fine.
    Filter in the Pic on the left is the OEM part # for my 2022 4 Runner which should still be the same for the 2024.
    icebear and Captain Spalding like this.
  3. Dec 25, 2024 at 9:20 AM
    OEM or Wix.
  4. Dec 25, 2024 at 9:51 AM
    Used Wix the last two oil changes. I can't see any difference from the oem.
  5. Dec 25, 2024 at 9:57 AM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
  6. Dec 25, 2024 at 9:57 AM
    94hokie
    94hokie New Member
    23 TRD ORP Lunar Rock
    Another thing I noticed recently is that Walmart actually carries Toyota OEM oil filters, so if you really want to avoid the dealership (at the expense of going to walmart), that's another option.
  7. Dec 25, 2024 at 10:11 AM
    kouack
    kouack New Member
    Prov. Of Québec, Canada
    4Runner Limited 2024
    Bone stock
    I would be a very hesitant to buy a Toyota oil filter @ Walmart not knowing if it is a knockoff one. At this point I would just go to a stealership and buy a pack of 10 or 20 filters and just not see their face for few years, or better just order them online from Toyota.
  8. Dec 25, 2024 at 10:18 AM
    The deal in post #5 above is great. That would cover me for the next 10 years worth of oil changes...I'm lucky to put 5k miles per year on the 4R.
  9. Dec 25, 2024 at 10:28 AM
    I personally buy from the dealer parts counter or RockAuto. I find it annoying going to the parts counter and the variable experience there but the prices that I’ve seen are solid for Toyota’s filter.
    In the past I’ve even used Walmart’s el cheapo SuperTech to solid results (granted, it was on a Kia with 3-4000 mile intervals) so I wouldn’t panic if Indid that occasionally but for the 4Runner I’ve mostly just picked up OEM and most recently, a batch of standard Wix 57173(?) filters.
  10. Dec 25, 2024 at 12:02 PM
    Denso 150-3020 filter, Dorman 65271 crush washer (OEM crush water sticks to the pan)
    https://www.rockauto.com/en/moreinfo.php?pk=6391380&cc=0&pt=5340&jsn=323
    https://www.rockauto.com/en/moreinfo.php?pk=3936945&cc=0&pt=5428&jsn=327&optionchoice=0-0-1-1
    You may be able to find both at local auto parts stores for less (no shipping charge).
  11. Dec 25, 2024 at 1:23 PM
    LarryDangerfield
    Tyler
  12. Dec 25, 2024 at 3:34 PM
    CHS4runner
    CHS4runner New Member
    DW
    2024 Black ORP
    No reason not to use the OEM filter. But, I’ve used a Mobil 1 filter in the past, it was also fine. Whatever is cheap and accessible is probably gonna be acceptable, but just load up on OEM ones for 5-6$ a pop.
  13. Dec 25, 2024 at 3:42 PM
    TN_FunRunner
    TN_FunRunner Custom Title
    Jay
    W. TN
    2018 TRD ORP, 2007 SR5 4WD
    OEM or Wix. Can’t go wrong with either.
  14. Dec 25, 2024 at 4:19 PM
    2ndGen22re
    CR
    Carson Valley, NV
    Thank you,
    I have gotten tired of the hassle of just buying 1 or 2 especially on a vehicle I know I’m going to keep a long time.
