Oil Filter placement and type on 2024 4Runner (V6 of course baby!)
Discussion in '5th Gen 4Runners (2010-2024)' started by NeverTooLate71, Jul 28, 2024.
  1. Jul 28, 2024 at 8:27 PM
    NeverTooLate71
    NeverTooLate71 [OP] New Member
    Bob
    2024 4Runner SR5
    After 1,100 miles I finally popped the hood for the 1st time since purchase. I fully anticipated seeing the oil filter placement up top of the engine instead of just like my old 06 Tacoma 4.0 V6. I see the guys on the Tacoma forum bitching and moaning about the oil filter placement and paper filter and was expecting the same. Pleasantly surprised....correct yes?
  2. Jul 28, 2024 at 9:30 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Your Post is a little confusing but the filter is on the bottom of the motor and is a paper canister filter. Stock skid has to come off to access
    LCJ77 likes this.
  3. Jul 29, 2024 at 5:29 AM
    The 4Runner filter is mildly annoying as it's a cartridge style filter. You need to clean and install a new O-ring on the filter housing every time, it adds an extra step and complicates things.
    I miss my older vehicles where I'd spin the filter off and immediately spin the new one on.
  4. Jul 29, 2024 at 5:44 AM
    Startrek
    Startrek New Member
    "After 1,100 miles I finally popped the hood for the 1st time since purchase" - is a testament to what?
  5. Jul 29, 2024 at 7:12 AM
    Uses the same filter wrench as the 2016-2023 Tacoma 3.5L but a taller filter cartridge.
  6. Jul 29, 2024 at 7:38 AM
    Schlappesepple
    Schlappesepple New Member
    2020 ORP
    Don't really know what the question is here, but you have to buy a 4th gen 4R for that.
    As often as I change the oil (personally), the cartridge filter doesn't bother me. I actually like having less trash to throw away, personally.
  7. Jul 29, 2024 at 12:19 PM
    Had the bolded part of this post said I fully anticipated seeing the oil filter placement up top of the engine, just like my old 06 Tacoma 4.0 V6 it would have made sense.
    I'm not quite sure what the pleasant surprise was.
    5thToy and LCJ77 like this.
  8. Jul 29, 2024 at 12:28 PM
    This is the updated 1GR with dual VVT-i and the different oil filter style and position that's been around in the FJ and Runner since 2010. The Tacoma never got it so that's
    2016Pro likes this.
  9. Jul 29, 2024 at 4:26 PM
    Maybe @NeverTooLate71 didn't like the top-mounted filter, which is very dependent on the anti-drainback valve to avoid dry starts.
  10. Jul 29, 2024 at 9:30 PM
    NeverTooLate71
    Bob
    2024 4Runner SR5
    Is that the purpose of the top mount oil filter? To mitigate dry starts?
  11. Jul 29, 2024 at 9:44 PM
    No real reason besides packaging.
  12. Jul 29, 2024 at 9:47 PM
    No. Top mount oil filter is more likely to cause dry starts if the anti-drainback valve in the filter leaks.
  13. Jul 30, 2024 at 4:05 AM
    Schlappesepple
    2020 ORP
    Can someone explain this dry start thing? I thought all starts are technically dry starts with any engine, if you're looking at the valve train or pistons (all the oil is in the oil pan, right?)
    Second, was this ever an issue for these engines? Lots of 4g 4R and 2g Tacos out there, and this thread is the first place I've seen it mentioned.
  14. Jul 30, 2024 at 6:22 AM
    A dry start is that second is takes to pressurize the oil system. The anti drainback valve prevents oil drainage from the filter back to the pan so pressurization takes less time.
