Oil dipstick level issue
Discussion in '3rd Gen 4Runners (1996-2002)' started by ToddsRunner, Feb 4, 2018.
  1. Feb 4, 2018 at 5:49 PM
    ToddsRunner
    ToddsRunner [OP] New Member
    Todd
    Utah
    96 4runner
    Rough Country's New 3-inch N2.0 Suspension Lift for '96-'02 models, KYB MonoMax front struts K&N air filter, braided front brake lines,Kenwood touch screen dvd player,10" sound stream subs . Rockfordfosgate mono amp. Cooper discover A/T Tires,17" Pro comp polished Aluminum rims
    Picked this 96 4Runner up and second owner of it. Motor was replaced with used 3.4 liter by owner and did oil change on truck and is showing low level on dipstick after putting in the 5.5 quarts required could it be wrong dipstick in engine ? And truck has no oil leaks nice and dry and coolant is perfect also.
  2. Feb 4, 2018 at 7:08 PM
    Toyotayoda
    Toyotayoda New Member
    Atlanta area
    1997 SR5 4x4, 302k and counting
    Tacoma whip, 99 console box, tru trac., steering wheel, PWMS and HVAC control out of a 99.
    Like below the low level line, or just not up at the full line? Officially the 4wd says 5.8qt, or 5.5L. Either way as long as the oil level is between the full and low marks that is ideal.
  3. Feb 4, 2018 at 8:03 PM
    ToddsRunner
    Todd
    Utah
    96 4runner
    Its around low mark maybe under
  4. Jan 27, 2021 at 7:06 PM
    CLeroux
    CLeroux New Member
    Megan
    '01 4Runner v6
    22" tires
    I've had my '01 4Runner for almost a year. I've always been puzzled by this, too. And I've even put a tiny bit of effort into finding out what the specs are on a genuine factory dipstick for my truck. Because it also seems this is the shortest oil dipstick I've ever used.
    Mine always reads on the bottom dots, even immediately after an oil change. I've had an 09 Prius and an 02 Highlander, and it's always been that the correct oil level will read perfectly in the middle of the two dots.
    but apparently, It's different for this 01 Highlander. The correct oil level seems to read on the bottom dot, what I would consider a low reading
  5. Jan 27, 2021 at 7:15 PM
    Very low on dipstick same on Corolla...
  6. Jan 27, 2021 at 7:16 PM
    The dealer will fill up to top dot. WAY overfull,, my advise, change it yourself..,,
    Toy4X4 likes this.
  7. Jan 27, 2021 at 8:16 PM
    Put the recommended amount in, then mark the dipstick.
    Toy4X4 likes this.
  8. Jan 28, 2021 at 12:13 PM
    I put near 6 qts in and get it to the high point. A little more oil never hurt an engine. I always thought it was a "lost in translation" thing. 5.8qts is 5.5L which I think is nearer to what I put it.
  9. Jan 28, 2021 at 8:29 PM
    RoxToy00
    RoxToy00 New Member
    rocky
    3rd owner of 2000 2whldr 4runner
    none
    "...a little more oil never hurt..."? Sorry to be so blunt, but have you never heard of the oil foaming and pressure disappearing and the motor seizing, from too much oil? Or is that just one of my fever dreams/nightmares caused by too much tequila? You know what they say about oil and alcohol.
    And I changed my '00s oil for prior owner for years with 5.5 quarts (amazing what uses pop up for that extra half quart sitting around); originally was dead middle between low and full dots, now continues to show barely above low dot. Don't think quarts have gotten smaller, but who knows. It doesn't seem to change when full six quarts are used, and I too worry about dipstick calibration, unexpected gremlins, and the fate of the dollar, but that's just me, lol.
    NewImprovedRon and Toy4X4 like this.
  10. Jan 28, 2021 at 8:36 PM
    The fumes come out the vents. If overfull. To little is better than too much..,
    Toy4X4 likes this.
  11. Jan 29, 2021 at 4:36 AM
    DGP1961
    DGP1961 New Member
    2018 SR5 Premium
    A "little more" won't foam up and cause issues, one or two quarts over all the time yeah maybe that's a different story. My "daily" is a Honda and that thing is super temperamental when checking the oil. I cannot check it while in the driveway because it has a VERY slight slope to it and it surprisingly throws the level way off. I'm talking the reading will be half a quart off from the driveway to checking it out on the flat street.
  12. Jan 29, 2021 at 7:56 AM
    Whoa...easy there killer. I said a LITTLE. :)
    SlvrSlug likes this.
