Oil change
Discussion in '4th Gen 4Runners (2003-2009)' started by Dawgn86, Jan 30, 2023.
  1. Jan 30, 2023 at 4:51 PM
    Dawgn86
    Dawgn86 [OP] New Member
    2006 4Runner
    Changed the oil in my in-laws 4 runner. 2006 4.0 with 163k miles
    probably 6000 miles since last change
    just dirty? Or other issues?
  2. Jan 30, 2023 at 5:08 PM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    Water/coolant in oil
    Check coolant level
  3. Jan 30, 2023 at 6:01 PM
    TX4runner21
    TX4runner21 New Member
    B-Rod
    Dallas, Texas
    '07 V8 4x4 T4R
    Fox Suspension, LFD Rack, Magnaflow Muffler
    Might be head gasket issue
  4. Jan 31, 2023 at 1:10 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    agree with the two replies. Possible coolant contamination
  5. Jan 31, 2023 at 1:33 PM
    +1 for potential head gasket. I believe the 1GR had some head gasket issues around that time.
  6. Jan 31, 2023 at 2:22 PM
    Dawgn86
    2006 4Runner
    Thanks for the replies
    Coolant was full in the radiator and at full mark in the reservoir.
    Hoping it was just past due for a change.
  7. Jan 31, 2023 at 3:58 PM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    That's not just past due.
    You are getting another fluid/water in there
  8. Feb 1, 2023 at 11:21 AM
    TX4runner21
    B-Rod
    Dallas, Texas
    '07 V8 4x4 T4R
    I think the head gasket issue was present up until 06 on the 4.0's
  9. Feb 1, 2023 at 1:05 PM
    Agree, that doesn’t look right. Unless the oil receptacle you were using was contaminated.
    Might be worth an early oil change, or at least a sample after a few hundred miles. I’ve read that if the vehicle is used for only short trips, water condensation may not have a chance to evaporate, and the water simply builds up to the point you start making mayonnaise. Could that be the issue, based on how they drive?
  10. Feb 1, 2023 at 1:51 PM
    Dawgn86
    2006 4Runner
    vehicle is used mainly for short trips around town; no real highway driving and speeds...I will keep an eye on it and change it early for them.
    Ironguy, Toy4X4 and Thatbassguy like this.
  11. Feb 1, 2023 at 3:09 PM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Tell them to get the vehicle out on the highway at least once a month if not more.
  12. Feb 2, 2023 at 2:46 AM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    Look on the VIN sticker on the driver's door jamb for the "build date", if it's after 12-05 then it has the upgraded head gaskets, 12-05 and before then it has the old style head gaskets and if so a bad head gasket is a possibility.
  13. Feb 2, 2023 at 3:21 AM
    If coolant is at proper levels, I would go with the short trips, water condensation. Oil temp. should reach 210F, if not a bit more to get moisture in the crankcase to evaporate, thus preventing the appearance of water/coolant. An extended trip at road speed will help.
  14. Feb 2, 2023 at 5:25 AM
    josephp732
    josephp732 New Member
    2019 Silver Limited, 2021 White TRD OR Premium
  15. Feb 2, 2023 at 9:59 AM
    spencermarkd
    spencermarkd New Member
    Spencer
    Pullman, WA
    2007 Driftwood Pearl SR5
    Second this. Looks like water in there from condensation and short trips. Did you have a nice yucky foam on the underside of the oil fill cap? I put in a cheap Amazon catch can to help filter out the water on mine and during the winter I'm emptying a good amount about once a month.
