OEM headlight upgrade
Discussion in 'Lighting' started by nkynaston, Mar 2, 2026.
  1. Mar 2, 2026 at 1:49 PM
    nkynaston
    nkynaston [OP] New Member
    2020 4runner
    I’m installing 2023 trd pro OEM headlights on my 2020. I’m planning on getting a wiring harness adapter that will also use the halogen DRL’s when the LED high beams are on. Has anyone switched out the DRL bulb? If so, is there a recommendation of a bulb that pairs well with the LED high’s?
  2. Mar 2, 2026 at 4:55 PM
  3. Mar 2, 2026 at 5:33 PM
    You are planning to use the existing 9005 wire that do double duty as DRL and Highbeam right?
    In my personal experience Xenon Depot LED Pro with DRL driver does not flicker in DRL more and give a decent highbeam output as a highbeam. But no where near bright as a high power LEDs with fans. But most LEDs with fans will flicker in DRL mode.
    Below example Headlight Revolution SV4 9005 in DRL mode vs Xenon Depot LED Pro in DRL mode.
    I saw this solution from VLED that seem to solve this problem. (But no personal experience though. Tempted to try.)
    https://www.vleds.com/catalog/product/view/id/4537
  4. Mar 2, 2026 at 7:42 PM
  5. Mar 24, 2026 at 6:49 PM
    AjRagno
    AjRagno New Member
    Minneapolis, MN
    2020 TRD ORP
    I have VLEDS low, high, and fogs in my 2020. The DRLs do not flicker.
    kmeeg[QUOTED] likes this.
  6. Mar 24, 2026 at 9:32 PM
    Charlievee
    Charlievee Not new member.
