oem brake rotor question
Discussion in '4th Gen 4Runners (2003-2009)' started by JeffsGT7, Jun 12, 2022.
  1. Jun 12, 2022 at 6:37 AM
    JeffsGT7
    JeffsGT7 [OP] New Member
    08 Navy SR5
    Good day all.
    Hope someone here really knows the answer here.
    I'm looking to replace front rotors (and pads) on my 4wd 2008 SR5.
    all stock, w/17" wheels
    What is the correct OEM part?
    43512-60151
    or
    43512-14266
    The Genuine Parts website seems to indicate both fit
    but being the wknd I can't call to confirm
    - after that what do ya'll like for pads?
    I've been an Akebono fan on my cars and because I tow think i would rather semi metallic vs ceramic
    Thank You
  2. Jun 12, 2022 at 7:40 AM
    spencermarkd
    spencermarkd New Member
    Spencer
    Pullman, WA
    2007 Driftwood Pearl SR5
    Your calipers should have a number and letter cast into them, either 13WH or 13WG.
    If it's 13WH, you have the larger 338mm rotors/caliper already and should get the 60151 rotors
    If it's 13WG, you have the smaller 319mm rotors/calipers and should get the 35322 rotors
    Also, might be worth looking into the 5th gen brakes conversion. You can use all toyota parts but get the larger/thicker rotors and calipers that are less likely to seize on you. (sorry to link offsite, haven't seen a good write up on here yet)
  3. Jun 12, 2022 at 12:47 PM
    JeffsGT7
    08 Navy SR5
    Hmm, that would be too easy.
    My RF Caliper has 10 4 83 cast in it
    LF all I can make out is 8 19
    could be aftermarket
  4. Jun 13, 2022 at 6:05 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    spencermarkd likes this.
  5. Jun 13, 2022 at 7:22 AM
    JeffsGT7
    08 Navy SR5
    ahh, stamped WG the backside - found it.
    Thanks all
