OEM Brake Pads-Which Ones?
Discussion in '5th Gen 4Runners (2010-2024)' started by Rocko9999, Feb 26, 2024.
  1. Feb 26, 2024 at 9:39 AM
    Rocko9999
    Rocko9999 [OP] New Member
    2011 Limited
    I need new rear brakes on my 2011 Limited. 2 OEM options pop up 1) 04466-60140 2)04466-AZ203. There is about a $15 difference between them. Any reason not to go with the more expensive option?
  2. Feb 26, 2024 at 9:57 AM
    ^04466-AZ203 shows as ceramic, less dust and less noise.
    Personally I go aftermarket with Bosch or Advics, as they come with new shims and hardware, whereas Toyota makes you buy them separately. Running Bosch BC606 ceramic pads myself.
    Rocko9999[QUOTED][OP] likes this.
  3. Feb 26, 2024 at 10:09 AM
    Rocko9999
    2011 Limited
    How long have you run the Bosch? Any noise with them?
  4. Feb 26, 2024 at 10:25 AM
    I run Advics AD0976 ceramic in front, and Bosch BC606 in the rear. Both are dead quiet and dust free.
    On humid mornings, there's squealing on the first couple of brake applications, that goes away as the flash rust on the rotors is rubbed off.
  5. Feb 26, 2024 at 10:27 AM
    I've used Bosch majority of the time whenever I replace brakes and no issues with them.
    Use Napa on time in my life and those things were crap after 5k miles.
    Rocko9999[OP] likes this.
  6. Feb 26, 2024 at 10:35 AM
    Rocko9999
    2011 Limited
    Thanks. I have the initial squeak when backing up. Had it on my Tundra too. I may look at those Bosch. I like having new hardware included.
  7. Feb 26, 2024 at 10:58 AM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    04466-60140 is what you need. The AZ ones are cheaper/budget category.
    JS222STL, nova and Rocko9999[OP] like this.
  8. Feb 26, 2024 at 1:17 PM
    Rocko9999
    2011 Limited
    Thanks.
  9. Feb 26, 2024 at 3:21 PM
    steelevo
    Utah
    Doesn't the more expensive one come with replacement shims also.
  10. Feb 26, 2024 at 3:23 PM
    Rocko9999
    2011 Limited
    Neither come with shims or rattle clips from the pictures. All separate.
  11. Feb 26, 2024 at 4:54 PM
    I’ve run these for years on my 2011 and will on my 2022 when they need it. Cant go wrong for $115 and comes with all the hardware.
  12. Feb 26, 2024 at 5:13 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    Best bet, go OE and pass on the inferior lifetime of the AZ pads:thumbsup:
  13. Feb 26, 2024 at 5:49 PM
    4R777
    4R777 New Member
    I use Akebono. They work amazing. Can't recall if they are the OEM or Toyota or not.
    Brake Parts
    Front Rotor 4351260191
    Front Brake Pads 0446560320
    Conicelli Toyota Bundle price for above: $148.95
    Front Shim Kit: 0494560090
    Front Caliper Pins: 4773560300
    Front Caliper Pin hold (Spring): 4774360280
    Front Caliper Springs (fitting kit): 0494735050
    Front Anti-Rattle Spring: 4774835010 (not needed if using fitting kit?)
    Rear Rotor 4243160311
    Rear Brake Pads 0446660140
    Conicelli Toyota Bundle price for above: $176.95
    Rear Shim Kit: 0494660141 / 0494660140
    Rear Caliper Fitting kit: 0494722050
    Alternative hardware kits:
    ACDelco Springs and Pins 18K2113X
    ACDelco 18K822X rear clips
    Carlson 13600 Front Brake Disc Hardware Kit
    Do Not Use - these kits
    Front Brake kit: 04465-AZ001-TM
    Rear Brake kit: 04466-AZ004-TM
  14. Feb 26, 2024 at 7:02 PM
    Lc200
    Lc200 New Member
    Pre Facelift SR5P
    Looking for a rear brake kit for myself.
    Is Conicelli Toyota a dealer that has the pads and rotors for both rear wheels for $176?
  15. Feb 27, 2024 at 8:29 AM
    Rocko9999
    2011 Limited
    Thanks. Do you know why there are two shim kits for the rear? Rear Shim Kit: 0494660141 / 0494660140. Is one left and one right side?
  16. Feb 28, 2024 at 1:30 AM
    Gripster
    Gripster New Member
    2016 Trail Premium
