Odd blowdown noise when shutting engine off
Discussion in '5th Gen 4Runners (2010-2024)' started by camit34, Oct 24, 2021.
  1. Oct 24, 2021 at 2:14 PM
    camit34
    camit34 [OP] New Member
    Aaron
    2022 & 1997 SR5s
    None yet
    Just picked it up Thursday evening with 3 miles on it. Today is Sunday and now has 170 miles. I do not recall hearing this sound until today. Any ideas?
    I did search but nothing matched this.
  2. Oct 24, 2021 at 2:15 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Air pump blowing the cat.
    Mtbpsych likes this.
  3. Oct 24, 2021 at 2:22 PM
    camit34
    Aaron
    2022 & 1997 SR5s
    None yet
    Searched it up and read a little about this and it blows for about a second to kick moisture out, apparently. Guess I did not notice this the last couple days over my giddy-ness of owning a new 4Runner!
    Thanks for the quick reply!
  4. Oct 24, 2021 at 2:24 PM
    LandCruiser
    East Bay Area
    5th Gen OG TE
    It also does it on start up if you listen very carefully.
  5. Oct 24, 2021 at 5:48 PM
    It's been awhile since I read about this system. Does the pump only kick on st engine shutdown.
    Is it specifically for the cats?
    If it's not emissions related, could we delete it?
    Thanks
  6. Oct 24, 2021 at 5:55 PM
    camit34
    Aaron
    2022 & 1997 SR5s
    None yet
    This thread seems to have a ton of info in it.
    BroRunner and DrewMan like this.
  7. Oct 24, 2021 at 6:08 PM
    Thank you for the link. Much appreciated. :)
    camit34[QUOTED][OP] likes this.
  8. Oct 24, 2021 at 6:35 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Learn something new 'every' day. Thanks guys:hattip:
    suaveflooder and camit34[OP] like this.
  9. Oct 24, 2021 at 6:48 PM
    brownersd
    Sean
    Humble / Kingwood, Texas
    It's a new thing, and not only on the 4Runners. Our 2020 Tacoma does it too.
    Cheers,
    Sean
    camit34[OP] likes this.
  10. Oct 24, 2021 at 8:00 PM
    Our 12' Sequoia has it too.
    Be nice if it could be eliminated. It would make spark plug changes much easier.
  11. Oct 24, 2021 at 8:26 PM
    Stoney Ranger
    Dave
    Driftless Area
    '18 SR5 Nauti Blue
    Mine farts,too.
  12. Oct 24, 2021 at 9:17 PM
    It’s the turbine flux capacitor rerouting power through the anti-matter plasma conduits. You don’t want to know what happens if you delete this part.
  13. Oct 25, 2021 at 12:33 PM
    iamincrediboy
    iamincrediboy New Member
    South FL
    Be mindful of what this link and the post it links talk about concerning failure of this system and our runners going into limp mode... the system started appearing on the '05 V8s when they introduced the VVTI system. aka exactly my rig. I literally just installed the Hewitt tech bypass system yesterday to to preempt the issue. The initial sound of it starting to sound like a vacuum over your engine, namely when its cold out and has been off for 7+ hours, is how you identify its starting to go on our older rigs.
    Food for thought :cheers:
  14. Oct 25, 2021 at 1:10 PM
    I got rid of the foam filter and replaced it with a breather filter to keep it from breaking apart and being sucked in.
    2Toys and camit34[OP] like this.
  15. Oct 28, 2021 at 4:33 AM
    ecoterragaia
    ecoterragaia New Member
    Central Virginia
    2021 SR5 4WD
    My 2006 Tacoma with the 4-cylinder (2TRFE) engine has the blower motor. Never had any problems with it in 12 yrs of ownership. On that truck it only activates on cold startup, and is supposed to inject air into the exhaust stream in order to heat the catalytic converters up faster. On the 4Runner it does the same, though I'm not sure why it briefly comes on when shutting the engine off.
