OBDLink MX+ OBD2 Bluetooth Scanner
Discussion in '5th Gen 4Runners (2010-2024)' started by Nemo, May 22, 2024.
  1. May 22, 2024 at 6:21 PM
    Nemo
    Nemo [OP] New Member
    Dave
    Oroville, CA
    2021 TRD OR Stock for now...
    Added all towing equipment
    I'm about ready to pull the trigger on ordering this OBD scanner for my 2021 4runner TRD OR. This OBDLink MX+ OBD2 Bluetooth Scanner (see link below) is supposed to work with my model year and can work with iphone and others. What do you guys think? Had any experience with this? It's a pricey when comparing to others but the fact that it works with a host of devices to broadcast to is amazing. Many only work with Android but this works with Android and iphone. I'm have a need for this 'cuz I returned my other scanner that I used one day but it didn't link with my vehicle very well.
    Here's the unit I think I like:
    https://www.amazon.com/OBDLink-Bluetooth-Professional-Grade-Diagnostic-Performance/dp/B07JFRFJG6
    I need this to monitor transmission temp (among other things) cuz I'll be hauling a small travel trailer occasionally (3000 lbs). Plus it makes sense to monitor the temp before bothering to buy a transmission cooler until I find I need one.
    So what do you experienced folks think? Thanks in advance for the help!!!
    Nemo
  2. May 22, 2024 at 6:30 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    I use this for monitoring the ATF. I like it nothing negative to report.
  3. May 22, 2024 at 6:54 PM
    In the past I use ELM327 Bluetooth for live data but I have faced few disconnects. I don't even want to share the link since I don't recommend it.
    Now I'm using this low profile wired Scanguage 2 and extremely happy with it.
    https://amzn.to/4bPnGPM
    Even though I don't own this, this is the new model they have Scanguage 3.
    https://amzn.to/3QXqfHT
    If I'm not mistaken Scanguage are the most trusted and reliable monitoring system around the globe.
    Adding a pic of mine -
    Nemo[OP] likes this.
  4. May 22, 2024 at 7:08 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
