Notification
Discussion in '5th Gen 4Runners (2010-2024)' started by hamsey, Jun 25, 2025 at 6:55 AM.
  1. Jun 25, 2025 at 6:55 AM
    hamsey
    hamsey [OP] New Member
    Norm
    Fraction Land
    2024 T4RLE
    Came across a couple of notifications on my info screen when checking the maintenance notification. I found a notification about the pre-collision system and another about the vehicle stability system. Both said to bring vehicle in to Toyota to inspect. I do not have any lights on the dashboard. Nothing in the app about these either. I did accidentally press the vehicle stability control button for a couple of seconds instead of the garage door button when pulling into the driveway. I don't recall seeing anything pop up on the dashboard. My only concern is the time that the notification appeared which was about 2.5 earlier than when I pressed the wrong button.
    My question is do I bring this in to get looked at? I did use the adaptive cruise control after I got the notification and it worked as it should keeping the correct distance with the vehicle in front of me.
    Thanks, Norm
  2. Jun 25, 2025 at 7:02 AM
    Someone else came across this and figured more than likely happened while the vehicle was being built due to the dates of the alerts.
  3. Jun 25, 2025 at 7:13 AM
    hamsey
    Norm
    Fraction Land
    2024 T4RLE
    Interesting! Gives the date but no year. It was built in June 2024. Happened on the same date that I missed buttons. If I clear it and there is a problem I'm guessing that the notification will come back? Thanks for reply.
  4. Jun 25, 2025 at 7:49 AM
    Yup just clear it out. If it was an active fault then you would be getting a consistent warning.
  5. Jun 25, 2025 at 8:54 AM
    hamsey
    Norm
    Fraction Land
    2024 T4RLE
    Will do. Makes sense since they are below the maintenance notifications. Again, thank you!
    whippersnapper02 likes this.
  6. Jun 25, 2025 at 9:09 AM
    I have encountered this simply because on the first one it was snowy and the sensor got blocked by snow. The second one I was off roading and it went off. I am sure if I check the maintenance log it will show them. I wouldnt worry about it
