Noob, limited 16 looking at wheel/tire options - plate lift
Discussion in 'New Member Introductions' started by Limited16, Dec 14, 2022.
  1. Dec 14, 2022 at 8:17 AM
    Limited16
    Limited16 [OP] New Member
    Hi All,
    Noob here and looking for someone with experience on the following.
    I'm looking to improve my limited 2016 winter tire selection, possibly with a plate lift to fit larger tires and smaller wheels. Is anyone happy with the plate lift? It's economical and I only want enough room so that I have access to more tire options. Current running the open country on the 20" rims, they rub a bit.
    Thank you,
    limited16
  2. Dec 14, 2022 at 8:49 AM
    kmeeg LionRunner
    Welcome..!!
    Sorry no experience with winter tire. But just curious 20in Toyo open country AT3 is bad in winter? Just asking since I'm interested in them.
    Limited16[OP] likes this.
  3. Dec 14, 2022 at 1:59 PM
    Welcome to the forum.
  4. Dec 14, 2022 at 6:00 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    Here is my '16 with Rough Country 2" front/ 1" rear spacer lift. Ride is still smooth as stock (because it pretty much is). Cost was $140, installed it in my garage in about 4 hours. It does what it is meant to do and I have zero complaints. That doesnt mean I will be taking it on any major trails but to lift the vehicle, its perfect. I have about 1" of rake front to rear. Tires are 275/70/17. No rubbing on turns after the lift (slight rub in reverse at full lock both sides). If you dont plan on doing any offroading other than an occasional dirt road, It should be plenty for you.
  5. Dec 14, 2022 at 7:56 PM
    Limited16
    Dirtrcr13, thank-you. That is what I'm just what I'm looking for. I do light off road, but need a soft tire selection and the small lift will help. I was worried about handling due to some comments on plate lifts. Great to know a bit more!
    DIRTRCR13 likes this.
  6. Dec 14, 2022 at 7:58 PM
    Limited16
  7. Dec 14, 2022 at 8:09 PM
    Limited16
    I erred, I have les schwab open range. I had the toyos on an f250. Both are good, especially in slush. Mine are getting towards replacement, and they aren't pure ice tires, meaning not the softer winter rubber that is winter only rubber. I'd put the toyos on now that I know the plate lift will work. They are a more open tread than open range.
  8. Dec 14, 2022 at 9:00 PM
    Limited16
  9. Dec 14, 2022 at 9:00 PM
    Limited16
    BTW, great look there
  10. Dec 14, 2022 at 9:38 PM
    4RunTM
    4RunTM New Member
    TM
    CA
    22' SR5P
    Your 4R looks good man.
    DIRTRCR13[QUOTED] likes this.
  11. Dec 16, 2022 at 4:32 PM
    DIRTRCR13
    Jerm
    The 405
    Spacer or plate lifts are not as bad as a lot of people make them out to be.
    There are 2 types of spacer kits.
    One goes between the spring at either the bottom perch (Westcott) or upper perch ( Daystar and others). These compress the spring a little more than stock to achieve lift.
    The other goes between the top hat and shock mount repositioning the shock downward to achieve lift.
    For what they are intended for, they work perfectly. But they are far from an ideal off road suspension set up.
    There are are a lot of common misconceptions about them though.
    1.Its a suspension upgrade. Nothing is correct about that statement. It does nothing but increase your ride height so nothing is "upgraded."
    2. It makes your ride better/ worse than stock. It does nothing to shock damping. If you use one that compresses the spring, as long as you dont over compress the spring, you will barley notice if at all.
  12. Dec 17, 2022 at 6:43 AM
    Ironguy New Member
    Welcome!
