Noise after lift kit installation
Discussion in '5th Gen 4Runners (2010-2024)' started by 2011_FoeRunner, Jun 10, 2025.
  1. Jun 10, 2025 at 8:35 PM
    2011_FoeRunner
    2011_FoeRunner [OP] New Member
    Hello y’all. Hope someone has some answers for me. I have a 2011 4Runner sr5. I installed an eibach stage 2 lift kit and jba UCA’s. I installed my lift kit a month ago, and I have been having issues with it. More of a noise. When I first got it back, I found my driver UCA loose since I was was hearing a clunking noise. I ended up taking it back, and he tighten it. But still till this day I still hear a clunk noise when I accelerate only. I’ve tried rocking my rig back and forth and couldn’t duplicate the noise that way. The noise ONLY comes when I accelerate and the noise doesn’t happen ALL the time but it does happen often. And the noise only happens on the driver side. I have took it back to the shop that installed it 2 times and he couldn’t find anything and I took it to another to look at it and he said everything looked tighten. Are they missing something or is there something else I can look at myself.
  2. Jun 10, 2025 at 9:04 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Common clunking comes from loose sway bar mounts, and end links. A big error people make is tightening the links without holding them with a hex wrench.
    Another common bolt not tightened to spec is the LCA cam bolts.
  3. Jun 10, 2025 at 9:32 PM
    brownersd
    Sean
    Humble / Kingwood, Texas
    Also mate, I have the Eibach Stage 2 lift. I had a clunk i was chasing for the longest time, and it ended up being the LCA cam bolts weren't torque correctly after I got an alignment. I chased that noise for about 7 months. I had another shop locally, check the bolt specs of all of the front suspension components, and indeed, the two LCA cam bolts were not torqued to the 135 lb ft (i believe) is required. Since then, not a sound.
    Cheers
    Sean
  4. Jun 11, 2025 at 3:17 AM
    2011_FoeRunner[OP] likes this.
  5. Jun 11, 2025 at 3:51 AM
    welcome
  6. Jun 11, 2025 at 4:05 AM
    Welcome from Wisconsin! The things to check and look at are pretty much what everybody above said.
  7. Jun 11, 2025 at 2:09 PM
    2011_FoeRunner
    Thank you!! I will look into this !
    brownersd[QUOTED] likes this.
  8. Jun 11, 2025 at 2:10 PM
    2011_FoeRunner
    thabn you I will recheck all of this today !
