No start no crank
Discussion in '4th Gen 4Runners (2003-2009)' started by mwgriffin, Mar 12, 2023.
  1. Mar 12, 2023 at 12:20 PM
    mwgriffin
    mwgriffin [OP] New Member
    2004was running idoling went dead all lights working on dash just nothing when turn key
  2. Mar 12, 2023 at 12:25 PM
    Pour Diet Coke on the battery terminals?
  3. Mar 12, 2023 at 12:56 PM
    GreatWhitePig
    GreatWhitePig New Member
    As in died while it was running? Alternator? But it would crank with a bad alternator I'd think, just not start.
    mwgriffin[QUOTED][OP] likes this.
  4. Mar 12, 2023 at 5:33 PM
    Get the battery tested. Check all fuses and grounds.
    Don't blame the alternator yet. Like was said, it would crank if the battery had a decent charge.
    If you have a very low battery, the engine can conk out while running...but usually runs rough for a bit first.
    If you charge the battery up, and it starts again, test and verify 14v+ across the battery terminals. Anything close to 13v and the alt is shot.
    But you have to check the battery out first.
    mwgriffin[OP] likes this.
  5. Mar 12, 2023 at 5:58 PM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    Check battery first
    Alternator second
    If non of the above start digging, ground, cables ect
  6. Mar 12, 2023 at 9:35 PM
    mwgriffin
    Ok thanks for the advice I tried charging battery was fully charged even jumper cables did nothing no click nothing has 300000 miles but is stil would go anywhere in it will keep trying anyway the check engine light doesn’t come on when turn key
  7. Mar 13, 2023 at 6:12 AM
    tblt44
    tblt44 New Member
    Todd
    Tampa
    2021 4 runner
    N/A
    A bad battery could cause this still.
    Pull battery and have it tested
    I once had a bad battery. Got nothing but interior lights,would not even turn over when jumping. They can short out internally and give you nothing for cracking amps
  8. Mar 13, 2023 at 7:06 PM
    mwgriffin
    Thanks I’ll try it hopefully it works miss driving it
