No Roof Rack
Discussion in '5th Gen Builds (2010-2024)' started by kennex53, Oct 16, 2022.
  1. Oct 16, 2022 at 5:14 PM
    kennex53
    kennex53 [OP] New Member
    Ben
    Saratoga Springs, NY
    2023 4Runner TRD Pro
    Does anyone have a 4Runner with the roof rack removed and replaced with nothing? I saw some pictures on another site with a 4Runner and no roof rack...it looked pretty cool and thinking of doing it with mine. To that end, would the old roof rack bolts be sufficient in keeping the roof water tight?
    Ice Cap Premium likes this.
  2. Oct 16, 2022 at 5:23 PM
    Potsie
    Potsie New Member
    2022 Army Green 4Runner ORP
    https://trail4runner.com/2019/05/07/5th-gen-4runner-roof-rack-delete-mod/
  3. Oct 16, 2022 at 5:24 PM
    kennex53
    Ben
    Thanks! :)
  4. Oct 16, 2022 at 5:25 PM
    Potsie
    Potsie New Member
    Np ! considering it myself because it looks great and I never use roof racks. Please share any info if you decide to do it. Post pics
  5. Oct 16, 2022 at 5:30 PM
    Georgetown, TX
    I removed mine
  6. Oct 16, 2022 at 5:32 PM
    kennex53
    Ben
    Definitely...I bought a Gobi Stealth about a year ago and it is nice and solid, but still so bulky and noisy. Plus, I haven't really used it as much as I had hoped. So now, I would like to see it all clean, even without the stock rack. The link you sent, said there is a kit for about $70 bucks. I will look into and probably do it...then post the pictures. Thanks again.
  7. Oct 16, 2022 at 6:36 PM
    ljerr2
    ljerr2 New Member
    IOWA
    2023 T4R Pro
    I'll be doing it to my 23 Pro when I get it later this month!
  8. Oct 16, 2022 at 7:02 PM
    Potsie
    Potsie New Member
    You guys that removed it what kit did you purchase and any tips when installing? Did you guys use silicone or just what came with the kit? Thanks!
  9. Oct 17, 2022 at 2:21 AM
    Georgetown, TX
    DIRTRCR13 and Potsie like this.
  10. Oct 17, 2022 at 10:04 PM
    Potsie
    Potsie New Member
  11. Oct 18, 2022 at 2:38 AM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    Water may pool in the roof ditches temporarily, but it will evaporate faster as well. The weather strip does not make a waterproof seal.
    Potsie and 7385 like this.
  12. Oct 18, 2022 at 8:24 AM
    Georgetown, TX
    The Cap does "technically" cover the Weatherstripping. But not by much at all. Hence the silicone to be safe. It's literally just the slightest of the edge to make a connection.
    No issues with that set up doing that for me. Weekly car washes and all.
  13. Oct 20, 2022 at 1:08 AM
    Potsie
    Potsie New Member
    I purchased the delete kit and after spending way too much time researching what types of sealants/silicone etc I still haven't made up my mind. I'm assuming the foam washer on the bracket and rubber washer on the bolt should be water tight if installed perfectly but I know how these things work. Nothing is machined perfect between the sheet metal,hardware/human error things are never perfect. I have some butyl rubber strips laying around that I might just wrap around the edges of the bracket. Thanks for uploading the pics. I'm trying to do it right so I'm not some sad guy posting about what not to do in 3 or 4 years when my truck needs a new roof and headliner
    7385 and Steely123 like this.
  14. Oct 20, 2022 at 4:46 AM
    ljerr2
    ljerr2 New Member
    IOWA
    2023 T4R Pro
    I think Toyota agrees with you and I believe that's why the manual calls for an anaerobic thread sealer on the bolt threads - as an extra precaution against water penetration/leakage.
  15. Oct 21, 2022 at 12:16 AM
    Potsie
    Potsie New Member
    Just an update. Ordered a knockoff kit from someone on ebay claiming oem and the foam on the brackets had little imperfections and small pieces missing. The covers had no numbers on the back and the bags they came in said made in japan. Ordered a kit from toyota and the foam on the brackets were fine. The bag from toyota said made in usa. Slightly different shade of black between the two. The knockoff kit would've worked fine if the foam on the brackets were intact. I'll post a picture or two if I decide to install this weekend
    djwantke likes this.
  16. Oct 26, 2022 at 7:19 PM
    kennex53
    Ben
    I bought the OEM stuff for $100 off Amazon, and will install soon. I think the silicon and plumbers tape should be good for stopping leaks.
    DIRTRCR13 likes this.
  17. Jan 2, 2023 at 5:12 AM
    KA5UTN
    KA5UTN New Member
    FL Panhandle
    2019 4Runner SR5 4x4
    Rago CB antenna mount, Rago dashboard shelf, 2m/70cm Ham radio install
    This may be a bit off topic, but I removed the roof rack from my 2003 4R myself. We discovered that a nice big rear shelf attached to the 2" hitch receiver, actually provided about 2mpg of gas mileage while the roof rack dropped our mpg by at least that amount. Good luck with the mod. 4Rs do look a lot sleeker without their roof racks IMNSHO.
    KA5UTN
  18. Jan 7, 2023 at 6:19 PM
    DIRTRCR13
    DIRTRCR13 New Member
    Jerm
    The 405
    '16 Sierra Romeo Cinco
    Thats what I used. The OEM kit should have only costs about $60ish from Scamazon. Should come with 8 bolts and washers, 4 clips and 4 covers. 2-3 wraps of teflon tape and a small bead of silicone grease ( NOT RTV!!!) around the washer. Get em nice and snug and you should be good to go. Been about 18 months and no leaks.
    djwantke and kolter45 like this.
  19. Jan 19, 2023 at 9:02 PM
    YetiMtnBkr
    YetiMtnBkr New Member
    Frederick, MD
    2021 LR Pro
    None
    I have been wanting to take my Pro Rack off even before I bought it 20 months ago. I never liked the look of the Pro Rack and I don't ever foresee me needing to use it. I have removed the rear seats and I have plenty of interior storage and sleeping space for me, myself and I. We have had a Chevy Suburban for 20 years (still have it) and the only time we used the roof rack was once a year for Christmas trees. In 30 years of marriage and with three active boys (now grown) we only used a roof rack for one trip in our Honda Pilot (still have it) to Maine for our Party of Five (borrowed a Thule roof top storage bin that worked very well). I am almost 61 now and given how rarely I used a roof rack over the past busy 30 years of my life - I think in full confidence I have no future roof rack needs. Looking forward to having sleeker look, a slightly quieter ride and maybe saving a ounce or two per fill up!
    WNC2018Limited likes this.
  20. Jan 20, 2023 at 12:38 AM
    Foothills
    Foothills New Member
    No need for roof rack if packed properly
  21. Apr 24, 2023 at 12:05 PM
    icestud
    icestud Mile High Member
    Matt
    2023 TRD Pro Solar Octane
    Why NO RTV?
    DIRTRCR13[QUOTED] likes this.
  22. Apr 24, 2023 at 3:41 PM
    DIRTRCR13
    Jerm
    The 405
    "NOT"... I was saying I did not use RTV. I was not saying to not use it. I chose not to use it. You can, but be aware that RTV has an acid in it, and when it cures it will peel/ bubble the paint. Being that the area is seldomly seen, but is susceptible to holding water, I didnt feel like having a rusty roof. But thats just me.
    icestud[QUOTED] likes this.
  23. Apr 24, 2023 at 4:43 PM
    WNC2018Limited
    WNC2018Limited New Member
    I just had the chrome factory roof rails taken off today at a 4x4 shop where I was having some other work done. I bought the Toyota kit for about $65 on Amazon. I had no need for the rails and think the truck looks better without them.
  24. Apr 24, 2023 at 5:11 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Meanwhile I'm like...
    Lol
  25. Apr 24, 2023 at 5:35 PM
    WNC2018Limited
    I think it largely depends on how many passengers you travel with when you take a trip. 99% of the time it's just me and my dog so there is room for all kinds of cargo inside the 4Runner.
  26. Apr 24, 2023 at 5:38 PM
    No man you're totally right, the hole plugs and rack delete looks awesome. I think if my wife and I got a second Toyota, which is coming, I could see how others have streamlined them off
  27. Apr 25, 2023 at 1:57 AM
    icestud
    Matt
    Thanks for the reply
  28. May 3, 2023 at 1:16 PM
    icestud
    Matt
  29. May 3, 2023 at 2:12 PM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I love this delete kit. I know it’s contrary to the purpose (and the thread, oops) but I think every aftermarket roof rack should come with this kit. I know several of them don’t “finish” the drip rail, but simply have spacers that bolt to the roof. The sealing plate underneath and the cover trim (just drill holes) are too useful to ignore.
  30. May 6, 2023 at 12:28 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    I do love the look of no rack. But I need a place to haul kayaks, lumber and such.
    YetiMtnBkr and icestud like this.
