No power steering at idle after return line change
Discussion in '4th Gen 4Runners (2003-2009)' started by Brent426, Jul 3, 2023.
  1. Jul 3, 2023 at 5:07 AM
    Brent426
    Brent426 [OP] New Member
    2008 sr5 4Runner
    I have a 2008 sr5 v6. I was getting a bunch of leaks and a whining pump so I replaced the pump and high pressure line. Drove it like that for about two weeks without problems but still a small leak from the return line. I swapped that last night and now I have no power steering unless I step on the gas. I tried bleeding the line but no more air seems to be coming out. Before I try flushing it again just figured I’d check and see if anyone had any ideas what’s causing this.
    3JOH22A likes this.
  2. Jul 5, 2023 at 4:51 AM
    Brent426
    2008 sr5 4Runner
    Just thought I’d add an update. The brand new pump I put in went bad. Don’t know why but I had a used pump from a different motor with a cracked mount. I JB welded it and stuck it in just to test and it works perfect.
    3JOH22A likes this.
  3. Jul 5, 2023 at 3:06 PM
    ^Thank you for the information. What brand was the pump that failed after two weeks? Was it new or reman?
