No crank, no start
Discussion in '4th Gen 4Runners (2003-2009)' started by dlhurd, Mar 12, 2016.
  1. Mar 12, 2016 at 6:24 PM
    dlhurd
    dlhurd [OP] New Member
    Dave
    07 4runner
    I have a 2007 Limited 4runner with the 4.0 V6 that is giving me fits.
    I recently replaced the 9 year old battery with a new one.
    Had no issues with the truck after that for a week.
    Noticed then that the rear wiper was not working. Checked all the fuses.
    Then found that the rear window was down just an inch or so. Put the window up and wiper was working fine.
    Got back in the truck to start it and now it does nothing. I have power to everything. But, turn the key and nothing. No noises, no clicking, nada! Just like that it quit starting. Jumpered from the battery to the starter solenoid and the starter works fine. Jumpered the STA relay in the underhood fuse box and the starter worked. I have meter checked all fuses that apply.
    Swapped out the STA relay with a new one as well as both STA fuses and no change.
    Tried starting it in neutral and park and shifting it around with no luck so pretty sure it is not the neutral safety switch issue.
    Note: The security system indicator lamp on the dash is not flashing. Pretty sure it used to flash. Makes me think the engine immobilizer may have kicked in somehow and shut the engine down. But if I understand that system correctly the engine should still spin over but not start. Instead of the engine just not spinning over at all. Is this correct?
    What the hell is going on here? I have been a mechanic for 40 years and never run into anything like this. Have talked to two 30 year Toyota mechanics and am still not getting it fixed. Very frustrated and disappointed in my 4runner. I am a loyal Toyota driver. Never had any issues like this with them.
    Can anyone help me? I have gone thru all the threads on this site as well as other sites and so far nothing is helping. It cant be this difficult. I must be missing something simple.
  2. Mar 13, 2016 at 10:35 AM
    T-Rex266
    T-Rex266 Moderator Staff Member
    I'm going to take a shot in the dark and say it's the alarm system...any way it can be pulled to test? Sounds like u have covered everything else
    RonT4R likes this.
  3. Mar 13, 2016 at 5:45 PM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    2007 4runner SR5 4WD
    I agree with Sean...
    T-Rex266 likes this.
  4. Mar 13, 2016 at 5:53 PM
    wnelax04sr5
    wnelax04sr5 New Member
    Ethan
    CT
    2004 SR5 4X4 Galactic Gray
    seans probably right, id start by pulling the battery and letting the ecu reset and seeing where that gets you
  5. Mar 14, 2016 at 10:32 AM
    dlhurd
    Dave
    07 4runner
    I did that. A couple times. Once for 30 min. then for overnight. No fix.
  6. Mar 14, 2016 at 11:43 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    Well if you rolled up your back window and it stop working, maybe the alarm system is hooked to the back window??? Try rolling it down a bit and see if it starts? Always go back to what you were doing when the problem occurred.:notsure:
  7. Mar 14, 2016 at 2:23 PM
    dlhurd
    Dave
    07 4runner
    Good thought, put the window back down.
    No start.
    I have since tried jumping the starter at the solenoid direct from the battery and had someone turn the key at the same time. The engine turned over but No start.
  8. Mar 14, 2016 at 3:44 PM
    wnelax04sr5
    Ethan
    CT
    i figured you did but thought i might as well say. do these motors have an immobilizer?
  9. Mar 15, 2016 at 5:56 AM
    RonT4R
    RonT4R New Member
    Ron
    Virginia Beach
    If I get time tonight I will comb through the schematic and see what could prevent it from starting. MY main guess is the alarm system, the question is the alarm factory? If the light was flashing and everything is working and now the light is not flashing and it will not start with the key, seem to me the alarm has disabled starting. I will look and see if they have factory alarm wiring in the factory manuals.
  10. Mar 16, 2016 at 5:53 PM
    dlhurd
    Dave
    07 4runner
    Discovered the ETCS fuse, #24, was blown. New fuse, started right up.
    Thanks for all input.
