Nitto Terra Grapplers to BFG KO2 “C” Load Rated
Discussion in '5th Gen 4Runners (2010-2024)' started by MooreKen, Oct 18, 2023.
  1. Oct 18, 2023 at 1:00 PM
    MooreKen
    MooreKen [OP] 2023 TRD PRO “Solar Octane”
    So I switched from the Nitto Terra Grapplers 265/70/17 to BFG KO2 265/70/17 w/ a “C” Load rating. Does my recommended PSI remain the same at 32 PSI as stated on the door placard? They put 41 PSI all the way around that’s why I’m wondering.
  2. Oct 18, 2023 at 1:05 PM
    The door sticker is for the OEM's that came with your truck. Go by the recommendation that Nitto has.; 41PSI.
  3. Oct 18, 2023 at 1:16 PM
    MooreKen
    I got rid of the Nittos but you are saying go with 41 PSI on the new BFGoodrich even though they are the same size but different load rating.
  4. Oct 18, 2023 at 1:31 PM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    If you were on P rated tires at 35 psi, you would now be at 47 psi for a C rated tire.
  5. Oct 18, 2023 at 1:36 PM
    2021venture
    2021venture New Member
    Todd
    2021 Venture
    50 psi is the max rated. I run mine at 35.
  6. Oct 18, 2023 at 1:38 PM
    I'm pretty dumb not understanding those tire psi charts but regardless the size of 265/70R17, 275/70R17, 285/70R17, 245/60R20, 275/55R20 I preffer to run 34ish psi on Standard Load and Load C tires.
    Since the ride quality is harsh on Load E tires I ran closer to 32psi but wish I could run lower for better comfort.
    MooreKen[OP] likes this.
  7. Oct 18, 2023 at 1:39 PM
    MooreKen
    I used the calculator and it came out 44PSI.
  8. Oct 18, 2023 at 2:48 PM
    I run 35-36.
    7Runner and MooreKen[OP] like this.
  9. Oct 18, 2023 at 2:52 PM
    Commited
    Commited New Member
    Oscar
    So Cal
    2019 Silver Metallic TRD ORP
    Tinted fronts, blacked out overlays.
    Sweet spot for C Load KO2’s is 35-36 psi
  10. Oct 18, 2023 at 2:55 PM
    Gstick
    Gstick New Member
    19' TRD OFF ROAD
    Sweet spot for me is 38 to 39 PSI with 6 ply KO2's.
    like2lean and MooreKen[OP] like this.
  11. Oct 19, 2023 at 8:22 AM
    MooreKen
    Thats exactly where I am at on comfort. BTW…. Spoke to Michelin/ BF Goodrich rep today and for a 2023 4Runner TRD Pro running the 6 ply KO2s they recommend 40 PSI for everyday driving.
  12. Oct 19, 2023 at 8:24 AM
    ToyotFan
    ToyotFan New Member
    2023 TRD ORP
    Are the Nittos good tires? I have crappy Bridgestone Duellers on my '23 ORP and am looking for new tires that can handle snow and some off-road that I may do. The price point for the Nittos is intriguing to me. I have also been looking at Goodyear Wrangler All Terrains and Duratracs as well.
  13. Oct 19, 2023 at 9:14 AM
    MooreKen
    I only had 4500 miles on mine and they were fine. Getting rid of them so early made no financial sense, I just wanted the more aggressive looking KO2s. The only time I found them to be a lil tricky was wet weather which is par for the course on A/T tires. I heard that they start getting really rough around 30K miles. Note I am talking about the Terra Grapplers (Hybrid Terrain) that came with the TRD Pro. I have heard good things about the Ridge Grappler which is a true A/T tire.
  14. Oct 19, 2023 at 9:21 AM
    I have the LT load Ridge Grapplers and they’ve been great. Most of my off road involves sharp rocks so that’s why I went with E load
    MooreKen[QUOTED][OP] likes this.
  15. Oct 19, 2023 at 9:26 AM
    Did you type by accident? Shouldn't it be Nitto Terra Grapplers that came with the TRD Pro are A/T and Nitto Ridge Grapplers are Hybrid Terrain?
  16. Oct 19, 2023 at 9:39 AM
    MooreKen
    I stand corrected…. I thought this entire time I had a hybrid tire because it was so smooth riding and everything I have read about the Ridge grappler made it sound like it was a competitor for the KO2 or Toyo A/T3. I just figured out the definition of hybrid being mud / AT…. I thought it was highway/ AT.
  17. Oct 19, 2023 at 1:34 PM
    TAT2
    TAT2 New Member
    I had my KO2’s swapped on new at purchase and the dealer aired them up to 40 PSI
