Nitto Terra Grappler G2s feel unstable
Discussion in 'Wheels & Tires' started by iamluckyb, Jan 9, 2021.
  1. Jan 9, 2021 at 10:08 AM
    iamluckyb
    iamluckyb [OP] New Member
    Bridget
    Phoenix, AZ
    2020 4Runner TRD ORP super white
    Nitto Terra Grappler G2 265/70/17; TRD Pro wheels; front/rear Bilstein 5100s; rear Durobumps; rear Icon 2” springs; PakRax sliders; raptor lights (amber, 3)
    **If there is already a thread somewhere on this (which I’m sure there is) that I just haven’t been able to find, feel free to direct me there!**
    I’m discouraged as I’m having problems with *significant* feelings of instability at highway speeds with my 265/70/17 Nitto Terra Grappler G2s. Like scary sway and feeling as if I’m driving on marbles. If the road is not completely smooth or there is a little bit of wind? Forget it. It gives me such anxiety to drive above 65mph that I have to pull over sometimes. I’ve just had the lugs re-torqued and the alignment is (or so I’m told) spot on.
    I’d say these tires have probably 500 miles or so on them at this point, and overall I have a much smoother ride after recent transition to the TRD Pro wheels and suspension upgrade to Bilstein 5100s all around. I’m new to all of this and don’t do my own work SO... what should I talk to my tire shop or lift shop about to help with this? I expected some trade-offs at highway speeds with getting AT tires but this is just depressing. Thanks in advance!
  2. Jan 9, 2021 at 10:25 AM
    If i were you, i would take it to a different place, explain to them how it feels to you. Don’t mention the alignment, let them tell you what they think, see how they handle it.
  3. Jan 9, 2021 at 11:20 AM
    iamluckyb
    Bridget
    Phoenix, AZ
    Somewhere to start. Thank you!
  4. Jan 9, 2021 at 11:21 AM
    20AGPro
    20AGPro New Member
    2020 Army Green TRD Pro 4Runner
    Sometimes psi can cause issues if too high or low.
    iamluckyb[OP] likes this.
  5. Jan 13, 2021 at 9:35 AM
    Agent_Outside
    Built 2011 T4R Limited
    Did you lift it without upper control arms? This sounds like the effect of to little caster.
  6. Jan 13, 2021 at 9:47 AM
    iamluckyb
    Bridget
    Phoenix, AZ
    Interesting. I was told by the shop that I wouldn’t need to change out the upper control arms unless I went up to a 3” lift. Right now it’s only lifted 2” in the front.
  7. Apr 16, 2021 at 8:08 PM
    JR7
    JR7 New Member
    2021 TRD ORP
    Way late to this thread but yes to this.
    I had an extremely floaty feeling and my truck (04’ Taco in this example) wandered all over the road. It was no bueno and when the wife drove it was terrifying.
    After some posting to the forums, I decided to check the psi and it was like 55 psi. I had the tires rotated the day before my road trip and someone at Discount over inflated big time. I aired down, and voila...
    2Toys likes this.
  8. Apr 16, 2021 at 9:17 PM
    iamluckyb
    Bridget
    Phoenix, AZ
    100%! I actually went back to that same tire place because they had overinflated them *again* and he, of course, justified it saying they know best blah blah blah. They finally agreed to lower them after I offered them to go drive it and feel what it felt like at 45+ something psi and report back. At any rate, I don’t go back there and now just do it myself. Live and learn!
    2Toys likes this.
  9. Apr 16, 2021 at 9:22 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Get an ARB deflator and run them at 34-36.
  10. Apr 17, 2021 at 1:48 AM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    Way late to this thread but weighing in just the same...
    ive got Nitto G2’s on my truck (07 Honda Ridgeline - yes I know some don’t think it’s a truck) and am very happy with them. I’ve got about 30k miles on them and they have delivered solid handling at all speeds. I do check air pressure myself and run 32-34.
    although I’m happy with them, will go with BFG K02’s on my 21 4Runner OR when I replace the Dunlop’s...
  11. Apr 17, 2021 at 6:53 AM
    What load range are your tires?
    Stock size SL rated tires should be run at 32, but LT tires at stock size "should" be run at 44 to maintain the proper load rating. This is the only reason I could see for them putting them so high.
  12. Apr 17, 2021 at 7:55 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
  13. Apr 17, 2021 at 9:12 AM
    Moon Landing[QUOTED] likes this.
  14. Apr 17, 2021 at 9:33 AM
    canadian.bacon
    Snowland
    ‘22 Tesla Model Y
    Even so, the default 32-34 psi is more than sufficient for the load. I’d definitely go back to 32 cold and take it from there, see how it feels. Don’t forget you’ll go up a few psi after a while at highway speeds.
    LandCruiser and Thatbassguy like this.
  15. Apr 17, 2021 at 9:39 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Is 32 giving the best wear, generally speaking? Mine arrived aired to 35 and move up to 38 on the open road. Suppose I should lose a few pounds :notsure:;)
  16. Apr 17, 2021 at 9:43 AM
    Right. But tire pressure is always measured cold.
    The point is that LT tires require higher pressure than SL tires for a given load. A tire retailer will inflate tires accordingly. So, if those tires are load range E, that would explain why the tire dealer would inflate them to 44 PSI.
    I would not necessarily run mine at 44, either. I'm just explaining why the dealer would inflate them so high. I had LT/C KO2's in stock size, and ran 35 and they rode great and wore perfectly.
    LandCruiser likes this.
  17. Apr 17, 2021 at 9:45 AM
    @iamluckyb can you post a picture of your alignment sheet?
    Moon Landing likes this.
  18. Apr 17, 2021 at 9:52 AM
    I always thought it made the most sense to start with the recommended pressure and adjust by how much weight I was hauling. Say you're hauling 500#, which is about 10% of the curb weight, I would add 3 PSI, or about 10%. This isn't technically the correct way, but it has worked well for me so far. :notsure:
  19. Apr 17, 2021 at 10:06 AM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Mine came with the no longer available 265/70/17 Terra Grappler(not G2) so, I called Nitto and was told 35 psi cold. Suppose i'll take measurements across the tire every now and then and see how they're doing? :notsure: either :rofl:
