Newbie Suspension Question - Bilstein 5100
Discussion in 'Suspension' started by tortega98, Aug 11, 2022.
  1. Aug 11, 2022 at 8:50 AM
    tortega98
    tortega98 [OP] New Member
    Tim
    2020 Red SR5 Premium XP
    So I just picked up a 2020 SR5 Premium and have been reading into suspension upgrades for it. I'm not gonna be doing a whole lot of off roading but want to at least improve the stiffness of the ride and level it.
    The consensus seems to be the 5100's are the best route for this but with people's experience, is it worth it to upgrade the coils to the old man emu's with it? What about UCA's, will those need to be upgraded also?
    Appreciate any insight!
  2. Aug 16, 2022 at 3:46 PM
    21TOR
    21TOR New Member
    2018 4Runner
    Some
    I went with Dobinsons and am very happy with them.
    hallcs and White Walker like this.
  3. Aug 16, 2022 at 5:17 PM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    You should think about how you plan to use your rig and plan your build accordingly. If all you want to do is firm up the ride, reduce the nosedive and level it, the Bilstein 5100’s are a good choice that won’t break the bank.
    I have a 2021 0ff Road and that’s exactly what I did and it made a big difference in the ride and leveled it to my taste. FWIW, I set the front shocks on the .85” setting and got 1” lift on OEM springs and UCA.
    But, I decided to make my rig more off road capable and put together a plan to add sliders, skid plates, hybrid bumper, winch and expedition roof rack. Needless to say, this adds weight and I needed to upgrade the suspension to handle it. I ended up changing OEM springs to Dobinsons with a 2” lift in front and 1” lift in the rear that could manage the extra weight. I reused the 5100’s with the fronts set to the OEM height setting and let the springs do the lifting. Although it was not required, I changed to JBA UCA just to ensure I could get the alignment set appropriately.
    I have finished the build and the set up is working well. It’s not a hard core off roader but more of an overland build.
    So, if you change to the 5100’s to firm up and level but don’t go beyond in your build, they will be a good choice but can also be part of a bit more aggressive build down the road…
    Cheers,
    Bob
  4. Aug 16, 2022 at 10:15 PM
    uda4021
    uda4021 New Member
    2020 Army Green TRD Pro 4Runner
    What set up with Dobinsons did you get?
  5. Aug 17, 2022 at 12:31 AM
    White Walker
    White Walker Double badass
    White trd pro
    Leveling kit, n fab turning boards 285 70 17s nitric ats
    Let's see more photos brother!!!
  6. Aug 17, 2022 at 12:34 AM
    White Walker
    White trd pro
    It really depends on your end game, seriously think about. Most guys start with I'm not going to do much offroad driving then after having you 4x4 for a bit and being on offroad forums such as this you start wanting more!!! Then you spend twice as much, I'm talking from experience brother. Alot of wasted money .
    I say go big or go home!!!
  7. Aug 17, 2022 at 10:55 AM
    BobbyB
    Bob
    Marietta, GA
    More Pics? Sure - here are a few...
    I've also added a UpTop Overland Bravo Rack and DiodeDynamic SS3 Pro fogs since these pics were taken...
  8. Aug 17, 2022 at 12:24 PM
    White Walker
    White trd pro
    Love the winch bumper :yes:
  9. Aug 17, 2022 at 1:16 PM
    ESCT4R
    ESCT4R New Member
    2022 TRD ORP
    I agree with what others are saying about spending a little more for a better suspension.
    If you're set on the 5100's, you shouldn't need to upgrade your UCA's. As far as coils go, I opted for the medium load Bilstein springs. I also have the Bilstein 6112/5160 set up. Which has been great thus far.
  10. Aug 19, 2022 at 2:50 PM
    Madmace
    Madmace New Member
    2022 Luna Rock Offroad 4Runner
    Bilstein 6112 with 1.6 lift and 1 in the back with B12 springs and 5100 shocks, Pro grill, Sequential turn signals, TRD matte black rims, Falken Wild Peak AT, TRD skid plate, Blackout kit, and Raptor lights.
    I went with 6112 set at 1.6 and 5100 in the with B12 springs to lift it 1 inch in the rear riding on falken wildpeaks 265s, I love the ride, but I have a rubbing issue in the front corners of the wheel well. So, I'm definitely changing the UCA's and do a diff drop to realign everything.
  11. Aug 20, 2022 at 6:12 PM
    21TOR
    21TOR New Member
    2018 4Runner
    Some
  12. Aug 20, 2022 at 6:23 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You can just get bilstein 5100 or eibachs, to level it out and improve body roll/brake drive). No need for coils or uca. Now if you want like a 2.5" front lift 1.5" rear , coils will be needed as well as uca
  13. Aug 20, 2022 at 6:26 PM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    Whats rubbing? Id reconsider
    nimby likes this.
  14. Aug 20, 2022 at 7:45 PM
    This will not correct your rub.
  15. Aug 20, 2022 at 9:07 PM
    Altitude4x4
    Altitude4x4 New Member
    2019 Voodoo Blue TRD Pro
    The fact these manufacturers sell these bumpers with terribly designed recovery points gives me anxiety.
  16. Aug 21, 2022 at 4:12 AM
    Madmace
    Madmace New Member
    When I'm backing up and I cut the wheel hard right or left on a slight incline it will rub on the very bottom corners of the plastic. IMG_2163.jpg IMG_2163.jpg IMG_2159.jpg
  17. Aug 21, 2022 at 6:13 AM
    hossler1788
    hossler1788 Turtle
    Joshua
    Central Pa
    2020 4runner
    You have to trim where it rubs..you know cut/remove/bend/heat however you wanna do it. just tastfully trim
    You do not need uca, or a diff drop with only 1.6" of lift.
    2Toys and nimby like this.
  18. Aug 21, 2022 at 6:45 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Cut it a 1/2 inch dude. And be done. No one would even know. Its what i did.
  19. Aug 21, 2022 at 11:36 AM
    This.
    Look up the fender liner mod for our vehicles. It will give you enough clearance so you don't rub anymore.
    Or, you could pay me the money you'd spend on the UCA's and diff drop and I'll do the fender liner mod for you :)
  20. Aug 22, 2022 at 5:06 AM
    Madmace
    Madmace New Member
    Thanks
    nimby likes this.
  21. Aug 22, 2022 at 3:51 PM
    TrailSpecial22 New Member
    PA
  22. Aug 22, 2022 at 3:56 PM
    PA
    Rubbing with stock tires and a lift? Somethings way off or alignment needs to be redone. No need to swap UCA or diff drop.
  23. Aug 22, 2022 at 3:58 PM
    PA
    I have a 2012 with 1.75” lift in front running 285/70/17 and had to trim a little off the bumper to clear. 265’s should clear with ease since they are the factory tire and no lift
  24. Aug 22, 2022 at 4:01 PM
    PA
    Are you sure they are 265’s and not 285’s?
    Toffees likes this.
  25. Aug 22, 2022 at 4:06 PM
    cereb6
    cereb6 New Member
    Chris
    2021 4Runner SR5 Premium.
    None.
    Bilstein 5100's, OME 884's up front and Bilstein 2" springs in the rear. Falken Wildpeak 285/70's. 4Runner.jpg
  26. Aug 22, 2022 at 5:11 PM
    Madmace
    Madmace New Member
    Definitely 265s I wanted to stay close to stock as possible for a little while, I hated the nosedive and body roll so changing the shocks was a game changer, it as more of a sports car feel to it now. I was hoping to avoid circumcising the fenders.:bananadance:
    Accelerator likes this.
  27. Aug 22, 2022 at 5:31 PM
    PA
    that is so strange they are that close with stock tires. I’ll have to take pics of mine in the morning and post my 265’s on my 2022 with a 2” lift for a comparison
  28. Aug 22, 2022 at 5:33 PM
    Madmace
    Madmace New Member
  29. Aug 22, 2022 at 5:35 PM
    PA
    heres one i had the day of the lift, bad angle but you can see all the room front and back.
  30. Aug 22, 2022 at 5:42 PM
    Madmace
    Madmace New Member
    I'm going to have another shop take a look at it, no need to rush.
