Newbie Question - Tires/Wheels/Lift Question
Discussion in 'Wheels & Tires' started by HH_UNDRGD, Jan 14, 2025.
  1. Jan 14, 2025 at 5:59 PM
    HH_UNDRGD
    HH_UNDRGD [OP] New Member
    Hey guys,
    I'm purchasing a 5th gen 4Runner SR5P in Underground! Excited to join the squad and forum.
    My first big purchase is gonna be for the lift and new shoes for the car. My list I'm thinking of is the following:
    • Dobinsons Lift Kit (2" front/1" rear)
    • RRW-7 wheels.. Looks like most on the site are 17x8.5. I do like the look of -10 offset but most likely will stick to +0 offset.
    • Falken Wildpeaks A/T4W (275/70/17)
    My question is, if I do the 2/1 lift.. Will 17x8.5 wheels with the 275/70/17 have any rubbing? I'd prefer to not have to change out UCAs and do a body mount chop. Does anyone have a similar setup or might be knowledgeable about this?
  2. Jan 15, 2025 at 4:40 AM
    welcome
  3. Jan 15, 2025 at 6:22 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Welcome!
    Lift wont help the rubbing on these rigs. If something rubs up front you'll just have to trim a little bit.
    I had a similar setup with RRW 17x8.5 -12 and 285/70/17 tires. The setup took a small amount bumper trimming and pushing the fender liners forward. Then also removing the front mud flaps. Went ahead with a body mount chop since it was getting pretty close when flexed out and I knew I'd want to with bigger tires eventually.
    Here are some photos of that setup.
    RRW 17x8.5 -12
    285/70/17 Nitto Ridge Grappler
    3" front, 2" rear lift
    UCA's to correct caster.
    Heres a good article on how to get some clearance up front.
    https://trail4runner.com/2019/07/14/fender-liner-push-back-trimming-on-4runner/
  4. Jan 15, 2025 at 6:38 AM
    HuskerRunner
    O,NE
    2023 SR5P
    Welcome.
    If you stick around, and you should, familiarize yourself with the search function. Especially the Search This Forum only box, from the forum that most closely matches what you need. You dont know it yet but this gets asked multiple times a week and 5th Gens are 15 years old.
    Chances are it wont rub, unless it does. In which case, chances are its just the front mud flap or maybe the fender liner, in reverse, unless its something else. 275s arent that much bigger than stock, but Falkens run big and no 2 4runners are exactly alike.
    1SilverRunner likes this.
