Newbee
Discussion in 'New Member Introductions' started by ToddJ, Feb 15, 2025.
  1. Feb 15, 2025 at 9:39 AM
    ToddJ
    ToddJ [OP] New Member
    Todd
    1996 Toyota 4 runner
    none
    Hey everyone, My name is Todd. I have a 1996 4runner and I would like help replacing the rear axle housing. I have replaced the seals in the left rear axle 4 times and it will not stop leaking. So, I bought a 1997 rear axle housing complete from a junk yard. It looks the same but with no rust, where mine is rusted badly. It was a 2 wheel dr as well, so I think all is good. Is there any diagrams to tell me what control arms or bushings I need to replace?
    Thanks in advance for the guidance.
  2. Feb 15, 2025 at 10:08 AM
    ToddJ[OP] likes this.
  3. Feb 15, 2025 at 10:11 AM
  4. Feb 15, 2025 at 10:25 AM
    welcome
  5. Feb 15, 2025 at 10:48 AM
    ToddJ
    Todd
    none
    Just so you all know, i am a youtube parts changer. i am not a mechanic. I ask, learn and watch videos to learn more.
  6. Feb 15, 2025 at 11:05 AM
  7. Feb 15, 2025 at 11:07 AM
    steelevo
    Utah
  8. Feb 15, 2025 at 11:11 AM
    ToddJ
    Todd
    none
    Well sir, thanks for the help!
  9. Feb 15, 2025 at 11:18 AM
    Up, down and all around!
    Welcome!
    Because it’s a fairly old (years) model, I would consider any bushing/rubber/plastics around the rear end to be ‘consummable’ and therefore should be replaced. Consider replacing any rusted bolt/nut and perhaps chase some threads while you’re at it.
  10. Feb 15, 2025 at 11:24 AM
    ToddJ
    Todd
    none
    Thanks for the advice, I will do that!
  11. Feb 15, 2025 at 11:26 AM
    ToddJ
    Todd
    none
    Thanks for the welcome and help all but one. My first thread and already getting bullied. i was trying to get advice, and help. I guess this is not the forum I thought it was!!!
  12. Feb 15, 2025 at 7:49 PM
    Startrek
    Startrek New Member
    pretty much everything that you disconnect
  13. Feb 15, 2025 at 9:05 PM
    DesertSurfer
    Welcome to the forum!
  14. Feb 16, 2025 at 5:05 AM
    Welcome from Wisconsin! Are you using the internals from the rear you're trying to stop leaking? Just in case you're not, are the gear ratios the same? As far as control arms and/or bushings, inspect them, if they are solid you're probably good to go.
  15. Feb 16, 2025 at 5:18 AM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Welcome!
    Why do you feel bullied ?
