New owner, is this normal engine sound?
Discussion in '5th Gen 4Runners (2010-2024)' started by Burgi, Sep 9, 2025 at 11:27 AM.
  1. Sep 9, 2025 at 11:27 AM
    Burgi
    Burgi [OP] New Member
    Tuesday
    Hello I just purchased a 2017 TRD ORP with 50k miles. The engine makes a pretty distinct knocking/clacking sound right by the driver side fender well. This is after about 10 mile drive, I feel like it’s even louder when cold. Is this normal? Thanks for all help.
    https://youtube.com/shorts/dPXPK5Wpjog?si=nvkKjTM_TrPslxsE
  2. Sep 9, 2025 at 11:33 AM
    2019 TRDP w/Kangs brah!
    Yes. These engines are not quiet. It's due to the shim under bucket valvetrain.
    Also yes it will make a pump noise at startup and shutdown and a buzz from the fuel tank after sitting for a few hours.
  3. Sep 9, 2025 at 11:42 AM
    White TuRD
    White TuRD New Member
    SC
    2021 TRD ORP
    Sounds good to me. The engine is early 2000s technology in all its glory (a good thing). Enjoy it!
    Burgi[OP] likes this.
  4. Sep 9, 2025 at 11:52 AM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    Yep. It'll rattle and shake like that for the next couple hundred thousand miles (at least).
    Tama1968 and Burgi[OP] like this.
  5. Sep 9, 2025 at 11:53 AM
    Texoma-Brad
    Texoma-Brad OK Yota
    Brad
    Texoma USA
    BTW, Welcome aboard!
  6. Sep 9, 2025 at 11:55 AM
    Burgi
    Tuesday
    Thank you guys for the reply’s. I got a great deal on the truck and was wondering if I just found out why I got a great deal.
    Texoma-Brad and djwantke like this.
  7. Sep 9, 2025 at 11:59 AM
    Welcome to the forum. I assure you, there are plenty of new owners who have asked the same thing, and a good portion of those didn't get any particularly good deal, some got taken to the cleaners to get the same engine sound. :cool:
    djwantke likes this.
  8. Sep 9, 2025 at 12:46 PM
  9. Sep 9, 2025 at 12:52 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
  10. Sep 9, 2025 at 2:12 PM
    Burgi
    Tuesday
    Also one last thing to note, the clacking sound is a lot more prominent when the transmission is in Park compared to Drive. Thanks again
  11. Sep 9, 2025 at 2:17 PM
    Yes, because the engine idles at a higher rpm in Park with no load on it (vs. churning the torque converter in Drive). You may get skid plate and/or interior panel rattles in one transmission setting vs. other setting.
    whippersnapper02 likes this.
  12. Sep 9, 2025 at 2:19 PM
    Also normal.
    A noise from the brake pedal area when first driving off is also normal.
  13. Sep 9, 2025 at 2:40 PM
    Burgi
    Tuesday
    Ok cool. I really appreciate all the feedback.
  14. Sep 9, 2025 at 4:43 PM
    When it goes quiet is when you start worrying. Lol!!
    Jk4runner, Burgi[OP] and Tama1968 like this.
  15. Sep 9, 2025 at 4:47 PM
  16. Sep 9, 2025 at 5:17 PM
    Jk4runner
    Jk4runner New Member
    Jeremy
    2011 sr5 4runner 4x4
    the 4.0 in the 5th gen 4runner use a roller rocker with hydraulic lifters. the tacoma and 4th gen runners use the cam on buckets valvetrain
  17. Sep 9, 2025 at 5:48 PM
    I knew it was roller rocker, but thought the shim was still in place. I wonder why they’re so damn loud?
  18. Sep 9, 2025 at 6:46 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    In park or neutral the engine has no resistance from the torque converter so the rpm rises a bit.
  19. Sep 9, 2025 at 6:48 PM
    Sin4R
    Distant land called Timbuktu
    2024 4Runner Limited
    Mall crawling kit.
    Not yet. You may find out when you take a closer look at the frame.
  20. Sep 9, 2025 at 7:13 PM
    Man, someone put a diesel engine in your T4R!
  21. Sep 9, 2025 at 9:06 PM
    Tama1968
    Tama1968 New Member
    Florida
    2018 SR5 Premium Magnetic Grey Metallic/2019 SR5 Celestial Silver
    Yeah, I thought I bought a diesel when I got my first 4Runner. Now my son and I both have one..another thing I noticed is these things move a ton of air. in the garage especially, sounds like a tornado . a diesel tornado.
    Saker likes this.
  22. Sep 9, 2025 at 10:01 PM
    Hungryhawk
    Hungryhawk New Member
    Southern CA
    2017 SR5
    Welcome, Do you have a maintenance history? Maybe no fluids or lubes serviced yet other than engine oil?
    I suggest considering Tranny, Transfer case (there are a few GL-4 suitable gear lubes), both diffs and all 6 propeller shaft grease zerks (technique required).
    I got my daughter a 2019 SR5 with 50,000 miles and all above lubes were due as all were original.
    If the technician changing your lubes can evaluate for simple age and not being discolored or burnt you will have peace of mind.
  23. Sep 10, 2025 at 2:30 AM
    Welcome from Wisconsin!
  24. Sep 10, 2025 at 3:50 AM
  25. Sep 10, 2025 at 5:17 AM
    Burgi
    Tuesday
    hi this is a local single owner vehicle that was serviced at the Toyota dealership its whole life. I got the records from the Toyota website and all the previous owner did was oil changes every 5-10k miles.also got new tires and a battery a few years ago.
    I just got the truck on Friday but so far I’ve done the differentials, transmission drain and fill, engine/cabin air filters and greased the driveshaft. My $130 per liter transfer case oil should arrive today so I’ll do the transfer case tonight.
    this weekend I’m going to do a coolant, brake fluid and power steering fluid flush.
    Hungryhawk[QUOTED] and Guppy1301 like this.
