Negatives to skid plates?
Discussion in 'General 4Runner Talk' started by Austin26, Mar 26, 2023.
  1. Mar 26, 2023 at 6:01 AM
    Austin26
    Austin26 [OP] New Member
    Austin
    5th gen ORP
    While installing one yesterday, I noticed it'll be a bear to get to a zerk fitting with the plate on. Are there any other negatives or things to consider now that the belly is all covered up? Thanks.
  2. Mar 26, 2023 at 6:05 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    '24 ORP
    I mean how often are you realistically greasing the prop shaft? Maybe every 15k, more? I think I've hit mine twice in 65k. Just take it off the couple times you need to grease stuff and consider the time investment the cost of protection.
  3. Mar 26, 2023 at 8:05 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Great idea to upgrade a skid. That's the biggest draw back is grease access, another negative on the engine skid in particular is oil plug access. Some brands have a bolt plated hole tho, others are all business. A third negative can be slightly less clearance from the depth of skids on areas that didn't have skids prior.
    Like buddy said just gotta invest the time to take em off and on! There's cheap torque wrenches too.
  4. Mar 26, 2023 at 8:24 AM
    Austin26
    Austin
    5th gen ORP
    My front skid provides fine access to filter and drain valve luckily. Just without a garage lift I'd rather never take these off. Getting the bolt on the cross member that went through the back of the engine skid and front of the tranny skid was quite difficult.
    I managed to round off a front skid bolt head but that was a me problem and not due to design.
  5. Mar 26, 2023 at 8:35 AM
    TrueTexas
    TrueTexas New Member
    The Woodlands, TX
    My problem has been that the stock skid plate has a standoff under the crossmember that allows you to jack up the entire front of the vehicle from the center of the skid. None of the aftermarket ones has this built in.
  6. Mar 26, 2023 at 8:39 AM
    My ARB kit makes contact with the stock jack point your talking about that's staggered slightly to the side for centre of balance. That's how we lift my front wheels
  7. Mar 26, 2023 at 11:08 AM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    Skid plates are heavy so fuel economy will suffer. Any bad thing that goes on under the car gets hidden like leaks or rust. They restrict airflow around hot parts. And from my experience, they tend to accumulate dirt and rocks that somehow gets kicked on top of them, especially if you have an oil leak.
    Austin26[OP] and djwantke like this.
  8. Mar 26, 2023 at 11:25 AM
    5six
    5six New Member
    55_4Runner
    GTA, Ontario, Canada
    2022 Black TRD ORP
    Skid plates definitely are not a “get and forget it item”. I’ve learned from members of another board is they need to be removed at least once a year to clean and review. One of the local guys removes his when he plans to take his truck the dealership, noting “better I remove it then have them f- it up.” I’ll be in that camp for the plates, but will leave on the diff skid.
  9. Mar 26, 2023 at 3:02 PM
    HotelMedicis
    HotelMedicis No Commercial Interests
    Intervals For Lubricating Propeller Shafts
    Toyota recommends the following intervals for lubricating the propeller shafts:
    Normal conditions: 15,000 miles
    Driving on dirt roads or dusty roads: 5,000 miles
    Driving while towing, using a car-top carrier, or heavy vehicle loading: 5,000 miles
    I always grease my zerks with every oil change at 5k. Land Cruiser was every 3k
    Thatbassguy and Austin26[OP] like this.
  10. Mar 26, 2023 at 4:28 PM
    Austin26
    Austin
    5th gen ORP
    Thanks. Those are some good points.
  11. Mar 26, 2023 at 6:40 PM
    The RCI front skid does. I jacked mine up from the center of the RCI skid and it did not deflect at all.
  12. Mar 27, 2023 at 7:17 AM
    v5ensx
    v5ensx New Member
    There should be no negative to skid plate.
  13. Mar 27, 2023 at 9:39 AM
    I’ve been deliberating on skids for a while since I tend to put a lot of miles on. I don’t mind taking them off for driveline greasing but some of them look to be a real pain in the butt to remove.
    My ideal skids would have protection wide enough to protect the LCA mounts, and good coverage on the transfer case, and the exhaust that crosses over.
    I’m having trouble finding anything that protects the LCA mounts.
    The transmission plates seem a bit redundant. I cant imaging dragging the front over anything big enough that would get anywhere near the transmission pan. So maybe I should mix and match and not use a transmission skid to make it easier to grease stuff?
  14. Mar 27, 2023 at 10:18 AM
    Sure that's a good route to go for skids, just the important high risk areas. Pretty sure there's specific LCA skids, as well as separate transfer case, and rear diff. I don't think they span
