Need You Help Please With Ignition Connector/Starting
Discussion in '3rd Gen 4Runners (1996-2002)' started by KV4Runner, May 11, 2019.
  1. May 11, 2019 at 4:18 PM
    KV4Runner
    KV4Runner [OP] New Member
    Hi All
    1998 4 Runner 4v4 SR5 with 315k miles. My ignition cylinder's metal rod literally broke but in an awkward spot where I cant just put a screwdriver in there to turn it to start. I took apart my steering housing, took off the airbag, pulled off the steering wheel.
    Then I went to remove my lock cylinder and it basically fell apart into pieces in my hand.
    So, I'm fairly certain I can hotwire my own vehicle. I tried jumping the starter fuse in the engine bay with a paperclip and it will turn over but not start all the way (not sure why?)
    Im assuming I can either put a paper clip into my ignition connector or cut the wires off of it and hotwire my car to a simple switch.
    I did a lot of research to no avail, Id love some help.
    Thanks in advance!
  2. May 13, 2019 at 3:39 AM
    KV4Runner
    Attached to the ignition harness is a plastic piece with about 8 copper "tits" and 2 copper rings. These rings turn as you turn the key and make connections to start the car. I was able to fiddle with the rings to make connections to get it to turn over but of course Id have to hold it. I ordered a $27 ignition part from Rock Auto to connect and I figure I can just use a screwdriver from that point on.
