Need Rocker Paneling to Allow for Nerf Steps but Shrockworks is Out of Business
Discussion in '5th Gen 4Runners (2010-2024)' started by mwsidler, Jan 24, 2023.
  1. Jan 24, 2023 at 2:12 PM
    mwsidler
    mwsidler [OP] New Member
    Michael
    2011 Toyota 4Runner SR5
    I want to install Nerf Step Bars on my 2011 SR5 but was told I need to purchase rocker panels from Shrockworks in order for it to be possible. Tried to order the paneling from Shrockworks just to find out they went out of business. Anyone know where else I can/should buy the necessary paneling?
  2. Jan 24, 2023 at 6:44 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Toyota
  3. Jan 29, 2023 at 7:43 PM
    JR1888
    JR1888 New Member
    JR
    2023 TRD ORP
    @mwsidler .. if you find out about any other alternative please let us know. It sucks if they went out of business, that was my next mod to my limited. Toyota seems to have them but boy are they costly.
  4. Jan 29, 2023 at 9:24 PM
    I’ve seen more than one thread about notching the rocker panels instead of replacing them…it’s another option.
  5. Jan 30, 2023 at 6:51 AM
    himileage
    himileage New Member
    2010 4Runner SR5 2wd & 2013 4Runner SR5 4WD
    I cut my stock rocker panel molding. I took a body saw and cut just below the chrome strip. Then I painted them black with truck bed liner. It was way better than spending $400+ on 2014+ rocker molding.
    Harringbr99 likes this.
  6. Jan 30, 2023 at 7:15 AM
    ^Is that just a piece of plastic that covers the pinch weld?
  7. Jan 30, 2023 at 7:18 AM
    himileage
    It fills the gap between the bottom of the door and the rocker. I didn't want mud and water hitting the weather stripping and caking up in there. It has worked well so far. It's only held on by the plastic push pins and a few screws. But with sliders or side steps you won't hit it much. Once you remove the moldings (be careful not to break the little push clips) you'll get a good idea of how to cut it. It was a pretty easy little mod. I'll be getting sliders soon so it would have to be done regardless. You can spend the $400+ on the 2014+ Toyota moldings and modify it to make it work but I wasn't worth it to me. I did go back and paint the pinch weld and the section just behind the molding with the black truck bed liner for protection and to hide it.
  8. Mar 3, 2023 at 6:44 AM
    SD4Run
    SD4Run New Member
    Jeremy
    2011 SR5
    Also looking for a solution, but I may just get sliders and cut my current panels in the mean time until I can grab something from a junk yard.
  9. Mar 3, 2023 at 10:35 AM
    Thepremier141
    Thepremier141 Member
    Nate
    Northern California
    ‘22 SR5P
    Toyota oem from an sr5, or junk yard might be your best bet.
  10. Apr 14, 2023 at 4:08 PM
    Dugger68
    Dugger68 New Member
  11. Jun 11, 2024 at 6:42 PM
    MikeinCC
    MikeinCC New Member
    2010 4Runner SR5 4WD
    none
    BUMP...too good not to.
