Need new rear coil springs
Discussion in '3rd Gen 4Runners (1996-2002)' started by kelbro, Jan 6, 2024.
  1. Jan 6, 2024 at 3:32 PM
    kelbro
    kelbro [OP] New Member
    NC
    2002 SR5 4Runner 2022 1794 Tundra
    Looking to replace my rear coil springs. Just bought some 5100s and need to finish the job. Not interested in lift as much as being able to tow my fishing boat without sagging. Maybe carrying a couple hundred pounds of corn in back every now and then.
    Is 2906 the answer? Seems like it from what I've been reading, I'm just a little concerned about too much lift.
    Thanks
  2. Jan 6, 2024 at 5:10 PM
    I used Duralast regained two inches of stock lift.
  3. Jan 6, 2024 at 8:29 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    Few things
    You're not interested in lift, but you purchased shocks that are longer than stock...which require a lift
    Are you willing to replace the shocks again? Bilstein 5100's are super cheap anyway as are Tokico's if you go that route
    As for OME906, they provide very little lift (1" to 1.5") and with just 150lbs at the rear you will sit near stock height
  4. Jan 7, 2024 at 3:02 AM
    kelbro
    NC
    Thanks. The 5100s were advertised as 0-2" lift so I assumed they would be fine at stock height. $100 a piece isn't 'cheap' in my book :)
  5. Jan 7, 2024 at 6:30 PM
    At stock height a shock for a lifted application has little to no travel left. You'll bottom them out. You MUST buy shocks for the correct ride height.
  6. Jan 8, 2024 at 5:51 AM
    kelbro
    NC
    I went ahead and bought the 2906 springs so I should be OK now, right?
    Thanks
  7. Jan 9, 2024 at 2:15 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    Tokico got bought by Hitachi a long time ago and for the most part left the shocks market. They made the original ones that came on the 4runner, and I'm sure Toyota still sells those for a high price. But Tokico's doesn't make that part for our 4runner anymore. KYB makes the best close to stock ones now (from what I've heard).
  8. Jan 9, 2024 at 3:00 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    KYB it is then
  9. Jan 13, 2024 at 5:08 PM
    kelbro
    NC
    2906s and 5100s did the job quite nicely. Added a slight rake too even though a level on the door sill says it's perfectly level now. The rake looks like the 5th gens.
  10. Jan 14, 2024 at 12:07 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    They'll settle some so expect to lose about 1/2" or more.
  11. Jan 14, 2024 at 2:49 AM
    kelbro
    NC
    Thanks. I wasn't sure how much to settling to expect. Should still look good. Beefy springs with a couple of extra coils up top. Got rid of the squat that happened when I hooked up my fishing boat.
  12. Jan 14, 2024 at 7:47 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    As long as you don't put much weight on them, because they compress quickly and easily.
