Need help with coolant leak from reservoir
Discussion in '5th Gen 4Runners (2010-2024)' started by Grug556, Jan 5, 2026.
  1. Jan 9, 2026 at 1:22 PM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    With how infrequent the cover comes off, removing the clips is easiest. Buy a bag of replacement clips if the originals don't hold well.
  2. Jan 9, 2026 at 1:33 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    I appreciate the input. FWIW, I'm only considering a small circular hole matching the radiator cap dimensions just below the cover.
  3. Jan 9, 2026 at 1:34 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    Thanks. I already have a bag of replacement clips. I've had the cover off a few times for work other than coolant replacement.
    Rocko9999[QUOTED] likes this.
  4. Jan 9, 2026 at 1:36 PM
    Grug556
    Grug556 [OP] New Member
    Kings, Crestone Rack, Baja S8, Baja Fogs, Baja XL80s, Baja mini cubes, SPOD, ARB compressor, RCI full skids, ROAM box and stuff. ST Pros. Shrockworks sliders... GOAT armour
    airflow is airflow. The underside of it has straits for laminization. Hard to say what it would effect. You would have to test it which is cumbersome. For the bother..i wouldnt
  5. Jan 9, 2026 at 2:52 PM
    Number16
    Number16 New Member
    2021 4runner
    I remember seeing a thread where someone cut it out for easier access. I don't remember which thread, though.
  6. Jan 9, 2026 at 3:35 PM
    Yes I did that:
    The area next to the hood latch is also commonly cut for winch access.
    5thToy[QUOTED] and eurowner like this.
  7. Jan 9, 2026 at 9:31 PM
    The 1.3 bar TRD cap raises the coolant boiling point by about 9 deg F. Use the TRD cap only if the rest of your cooling system has been upgraded for "racing development" - CSF all-aluminum radiator, Mishimoto silicone hoses, T-bolt clamps, etc.
    AuSeeker[QUOTED] likes this.
