Need help with a new back window problem (Rolls up but not back down)
Discussion in '1st Gen 4Runners (1984-1989)' started by 757Hokie, Mar 23, 2021.
  1. Mar 23, 2021 at 12:58 PM
    757Hokie
    757Hokie [OP] New Member
    Tristan
    1986 SR5
    Howdy everyone!
    First post here, but I cant find what I'm looking for anywhere. I have done loads of back window troubleshooting and fixes already and my '86 has had a working rear window until recently.
    The rear window will roll up just about all the way and then stops 1/2 inch short when using the switch. It then will not roll up or down. I removed the back panel and used direct power to the motor to get it to roll up to completion and direct power will let it go back down again as well. Once the original circuit is reconnected it works fine unless I roll it up to almost the top again. Im stumped, its very strange to me. I also tried bypassing the door latch switch and that doesn't change anything. I really hate to take the back panel off from inside to jump this motor, its getting annoying. Anything helps.
    Cheers
  2. Mar 23, 2021 at 8:51 PM
    36tacundra
    36tacundra New Member
    Maybe its the back door limit switch. The switch is grounded when the window is rolled all the way up. I wonder if it is getting grounded too soon. It is a switch that is attached to the regulator.
  3. Mar 24, 2021 at 6:26 AM
    se7enine
    se7enine New Member
    1984 4Runner
    3RZ
    Make sure the rear wiper is fully seated up. I want to say that has a sensor on it as well for the window.
