Need help with 1993 4 runner
Discussion in '2nd Gen 4Runners (1990-1995)' started by Matt93runner, Jun 18, 2020.
  1. Jun 18, 2020 at 1:07 PM
    Matt93runner
    Matt93runner [OP] New Member
    Matt
    1993 4 runner
    Hi everyone new to the page I have a 1993 4 runner it cranks and runs fine no issues when I put it in Drive it runs fine in first gear but when it shifts into second I loose all power and it dies doesn’t do it every time sometime it will shift into another gear and then die I’m no mechanic but my friend is and we’ve checked fuel pressure it’s fine it started doing this after I let the tank run might near out cause it was spitting and sputtering some I just thought it was old fuel in the tank thanks for any help you can give
  2. Jun 18, 2020 at 1:20 PM
    I don’t have a remedy for you, but welcome to the forum. Someone will chime in soon, be patient.
  3. Jun 18, 2020 at 2:51 PM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    Fourtoad likes this.
  4. Jun 18, 2020 at 6:08 PM
    Matt93runner
    Matt
    1993 4 runner
    Thank you I’ll give that a try
  5. Jun 18, 2020 at 8:49 PM
    japhroe
    japhroe New Member
    Jdiddy
    1994 4runner 2WD AT
    ALL STOCK 100%
    Please make sure you get the right tranny fluid it’s regular old school Toyota Dex, NOT the IV and NOT the WS.. Just FYI...✌️
    BlueGoo92 likes this.
  6. Jun 19, 2020 at 10:19 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    Is it throwing any codes?
  7. Jun 19, 2020 at 10:54 AM
    namrog456
    namrog456 New Member
    DTX
    1995 4R SR5 Auto - SOLD 2017 TRD Pro 4R - SOLD 2022 TRD Pro Tundra
    I had a '95. I had an issue with power consistency - it would crank and run just fine but lose power randomly (at low RPMs).
    Have you checked your spark plugs, distributor, and MAF?
  8. Jun 19, 2020 at 2:14 PM
    Matt93runner
    Matt
    1993 4 runner
    Not thrown any codes I haven’t checked spark plugs or distributor that’s the next thing I’ll check after I try the solenoids
  9. Jul 6, 2020 at 8:52 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    What is the fuel pressure and how consistent is it when you change the engine speed? You said you ran it dry in the tank so guess what any sediment in there went for a ride through the strainer and into the fuel filter which is behind one of the torsion bar anchor housings and is a right pisser to remove which means it doesn't get changed as often as it probably should.
    The auto trans and the ECM do swap some information so that might have something to do with the gear change and power loss but I am not super familiar with the automatic transmission equipped 4Runner's!
  10. Sep 6, 2020 at 1:03 PM
    Kazter Troy
    Kazter Troy New Member
    95 v6 4x4 z
    Check the #2 Vehicle Speed Sensor. That's on drivers side just above the gear selector input shaft. It tells the computer the input speed into the transmission and helps configure shift timing.
    Let me tell you from experience that little sensor can convince your engine to do stupid stuff. Convince you and a good transmission mechanic that the tranny is fried. Check the Tps also.
    duke759 likes this.
  11. Oct 30, 2020 at 8:37 PM
    duke759
    duke759 New Member
    1993 4Runner
    "Check the #2 Vehicle Speed Sensor" Please show where is the #2 sensor located.
