NEED HELP! Rear light fuse
Discussion in '5th Gen 4Runners (2010-2024)' started by Brown67d, Aug 28, 2025 at 10:09 AM.
  1. Aug 28, 2025 at 10:09 AM
    Brown67d
    Brown67d [OP] New Member
    Rob
    2013 4runner limited
    None
    Ho everyone, Im in a bind. I replaced my headlights with aftermarket ones and now my real lights won't work. Upon further inspection the interior 10 amp fuse keeps blowing the second it get power.
    After reading the wiring diagram it appears that the front side marker lights are on the same circuit as the rear brake lights.
    Side marker lights are working fine.
    It's acting like a ground fault
    Has anyone else experienced this issue or have any idea why it would blow?
  2. Aug 28, 2025 at 10:34 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Re-install the OEM lights. If that fixes the problem, you know what the culprit is. You didn't specify the brand of aftermarket headlights, but I'm guessing low quality Chineseium. Most folks don't have issues with the more expensive, but quality products from companies like Morimoto, etc.
  3. Aug 28, 2025 at 10:51 AM
    Brown67d
    Rob
    None
    Unfortunately the oem ones are gone. These are from LED factory. They weren't cheap (1,000) but yeah not high quality
  4. Aug 28, 2025 at 3:36 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    Put a 15 amp fuse in and if keeps blowing it you prolly have a ground issue. Are you running resistors with the LED's? I've run into this before with a Ford F350 and resistors and an aftermarket flasher relay fixed my problem.
    This link may help
    https://www.tacomaworld.com/threads/installed-led-turns-keeps-blowing-10a-tail-fuse.468925/page-2
  5. Aug 28, 2025 at 4:46 PM
    If it just started after replacing headlamps, Head back to the headlamps and see if you pinched a wire during install. Hard to believe you would have Vegas like odds on a direct to ground short at the same time you installed your new headlamp assemblies.
