Need help from 4runner with power socket
Discussion in '5th Gen 4Runners (2010-2024)' started by jev425, Oct 12, 2024.
  1. Oct 12, 2024 at 3:49 PM
    jev425
    jev425 [OP] New Member
    Seattle
    2022 Nautical Blue TRD Off-road
    Looking for someone that has the power socket(cigarette) up front under the A/C controls. Can you take a pic of what it looks like closed and with the cover open. I am looking to change out my USB-A dual ports to the socket but can't figure out item number for the plastic cover.
    thanks!
  2. Oct 12, 2024 at 4:45 PM
  3. Oct 12, 2024 at 4:48 PM
    I think there may be a change mid-year. Check the production date of your vehicle.
  4. Oct 12, 2024 at 4:53 PM
    jev425
    Seattle
    awesome that looks like it should be it! I was able to get my hands on the actual socket that goes inside this cover. Hoping I have the correct socket. We will see
  5. Oct 12, 2024 at 5:42 PM
    Imdav2u
    23 TRD PRO
    Why don't you want dual ports? I have been thinking about changing mine to the dual usb.
  6. Oct 12, 2024 at 5:51 PM
    jev425
    Seattle
    They are nice but all of my devices use usb-c to charge so I rather have the faster charging from the power socket with a plug in charger with dual usb-c plugs.
    Captain Spalding likes this.
  7. Oct 12, 2024 at 6:07 PM
    Imdav2u
    23 TRD PRO
    I thought about getting this dual usb c charger.
  8. Oct 12, 2024 at 7:51 PM
    OdyRunner
    OdyRunner New Member
    I have the 50W version that I use to charge my iPad, which I use for navigation, plus whatever the passenger has, usually another iPad or iPhone. Haven't had any issues with it yet. For reference I have had mine for almost year now.
  9. Oct 12, 2024 at 8:18 PM
    Imdav2u
    23 TRD PRO
    Anker?
  10. Oct 12, 2024 at 8:24 PM
    OdyRunner
    Yep the Anker 50W unit.
  11. Oct 12, 2024 at 8:26 PM
    Imdav2u
    23 TRD PRO
    I have a 50 watt , not Anker, with usb a and usb c in the console. It changes my s24+ extremely fast.
  12. Oct 13, 2024 at 5:42 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
  13. Oct 13, 2024 at 6:17 AM
    OdyRunner
  14. Oct 13, 2024 at 1:19 PM
    Blu’s Dad
    Blu’s Dad New Member
    Northern Virginia
    2020 Limited
    Although you can’t always believe the internet, shocking I know, but I thought I read a caution on using these adapters, as they may f—up the electronics - device and/or vehicle?
  15. Oct 13, 2024 at 2:21 PM
    In the case of the 4Runner I don’t think so. It’s a pretty simple circuit. Battery to switch side of ACC relay to P/Outlet fuse to 3 power outlets.
  16. Oct 13, 2024 at 2:31 PM
    @jev425 The combined capacity of the three stock power outlets is 120 watts. Not to overcomplicate things, but you might want to give your new power outlet its own circuit from the battery, through a fused relay (that is energized by a switched circuit) and then to your outlet. That way you add not only outlets, but capacity as well.
  17. Oct 13, 2024 at 4:24 PM
    OdyRunner
    The 12V outlet I plug mine into has been rewired to be always on and is fused separately from the other 12V outlets.
  18. Oct 13, 2024 at 5:38 PM
    Do you have anything plugged in. Is there excessive battery drain?
  19. Oct 13, 2024 at 7:26 PM
    java
    java fauxrunner
    2023 ORP ice cap
    My Anker drops to low 40w while charging my jackery after a few mins :((
  20. Oct 14, 2024 at 8:16 PM
    OdyRunner
    I haven't had any issues so far and I have had the iPad plugged in overnight along with my garmin inreach.
    I haven't measured the wattage on mine yet. How are you measuring it?
  21. Oct 14, 2024 at 8:31 PM
    java
    java fauxrunner
    2023 ORP ice cap
    Jackery displays input power.
  22. Oct 15, 2024 at 12:31 PM
    jev425
    Seattle
    got it swapped over and figured out the correct part numbers for the socket and plastic cover
  23. Oct 15, 2024 at 1:14 PM
    Imdav2u
    23 TRD PRO
    Is your old socket for sale?
