N Fabs Installed on 2019 Nightshade
Discussion in '5th Gen 4Runners (2010-2024)' started by Steve40th, Aug 17, 2022.
  1. Aug 17, 2022 at 3:17 PM
    Steve40th
    Steve40th [OP] New Member
    sTEVE
    Well, I installed them. They are not a perfect fit. Drivers/passenger side front needed the factory bracket bent ever so slight to fit.
    They do touch the front where n fabs curve in to the lower panel. Barely.
    15ft/lbs of torque seems weak, but I used loctite and my torque wrench.
    4RunnerGunner and Slopemaster like this.
  2. Aug 17, 2022 at 3:21 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Looks great!
    Steve40th[OP] likes this.
  3. Aug 17, 2022 at 3:29 PM
    Looking good.
    I wonder what is the height from ground to the bottom of the step / under the step. To see how much clearance these is. Might help other members i guess.
  4. Aug 17, 2022 at 3:36 PM
    Steve40th
    sTEVE
    Drivers side, center of step 8.5", passenger side front 9"
    Drivers side passenger 9", passenger side back 9.5.
    Engineered perfectly...lol
    My runner has the lean.
  5. Aug 17, 2022 at 3:45 PM
    if you have 8.5inch with N-fabs that is a very good clearance for Limited / TRD Sport imo..:cheers:
  6. Aug 17, 2022 at 3:48 PM
    Steve40th
    sTEVE
    I will be lifting it soon. Probably going Eibach Pros, and remove the factory Limited system.. Not a high enough to warrant new UCA, just level and raise it a bit.
  7. Aug 17, 2022 at 3:52 PM
    Hope you have done your research. I've tried few but none good as XREAS on-road to my taste. Not even the crazy expensive ELKA 2.5DC where people say "Ride like Cadillac" / "Butter smooth" :D:D I have no experience with Eibach Pros, so can't say anything on that.
    Steve40th[QUOTED][OP] likes this.
  8. Aug 17, 2022 at 3:53 PM
    Steve40th
    sTEVE
    I wish the manufacturer would post real specs of the hydraulic shocks. We all know what the springs are, but with hydraulics, what are the specs, rebound compression etc. Otherwise, its trial and error..
    kmeeg likes this.
