Mysterious wet patch on block of engine
Discussion in '4th Gen 4Runners (2003-2009)' started by Evo999, Jul 6, 2025 at 7:56 PM.
  1. Jul 6, 2025 at 7:56 PM
    Evo999
    Evo999 [OP] New Member
    Hey friends! Looking to see if anyone has experienced this on their 2003 v8 4Runner. Mines a 4x4. I was doing some visual check of any major leaks and found what appears to be a wet or damp area from the driver side starting from what appears to be between the engine block. I did have a valve cover gasket leak that was repaired 2 months ago. Could this be left over leak from the valve cover during its time? I just hope it’s not a headgasket leak which I doubt. Here’s a video for visuals.
    https://youtu.be/D-Ox4osMpYw
    LOSTR4 likes this.
  2. Jul 9, 2025 at 8:22 AM
    LOSTR4
    LOSTR4 New Member
    Just a couple
    Clean it up with some oven cleaner and than monitor it. It very well could be residual leaking before the VC seal replacement...however, perhaps the ozring on your dip stick is leaking oil past...?
