Can I install a small block chevy in my 90 4Runner?
Discussion in '2nd Gen 4Runners (1990-1995)' started by jenegirl4ever, Feb 16, 2021.
  1. Feb 16, 2021 at 12:16 PM
    jenegirl4ever
    jenegirl4ever [OP] New Member
    jennifer
    90 yota
    i have a rod knock so my question is
    can i put a small block chevy in her? i know i have to modify motor mounts if i did what else would i have to change?
  2. Feb 16, 2021 at 12:23 PM
    Mtbpsych
    Mtbpsych New Member
    Everything related to the power train.
    I’m not a mechanic, but I don’t see anything stock working with a new engine and transmission.
  3. Feb 16, 2021 at 1:19 PM
    Moon Landing
    Jer
    Moon Rock 4Runner
    Nam 68/69
    Anything can be done. For a price. I'd do a whole lot of searches first........tons. If you decide to, I'd love to follow along. So, let us know.
    EDIT: Google this > adapt chevy small block to Toyota 4runner - it's a beginning.
    https://www.youtube.com/watch?v=j7n8MsPtIVI
    https://www.youtube.com/watch?v=u0YYzj5xJc0
  4. Feb 16, 2021 at 2:10 PM
    jenegirl4ever
    jennifer
    90 yota
    will do and thanks
  5. Feb 17, 2021 at 7:59 AM
    D60
    D60 New Member
    If you don't have fab capability and experience with prior engine swaps, I'd probably look for a 3.4. That swap is well documented and is Toy to Toy
    That said, a 5.3 GM would be ridiculously sweet, but never cheap to do it right
    atgparker and Tama1968 like this.
  6. Feb 17, 2021 at 8:01 AM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    2010 Zombie Truck
    Please see signature!
    Years ago (2003-2004ish), I saw a 2nd Gen T4R 2WD on eBay that had a 350 in it; If I remember correctly, it even had the factory A/C hooked up!
    I also saw a 1980s Toyota pickup with a Lexus V8 and a 5-speed stick in it at a car show back in 2018! Anything is possible; It all comes down to how much you're willing to spend!
  7. Feb 19, 2021 at 2:04 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    Power to weight ratio is what you want to optimize if you are looking to do this. A small block Chevy is a heavy cast iron block engine. Now the 3.0L 3VZ-E is also cast iron but it is a relatively small V6.
    So taking that into consideration if and when I decide to rid myself of my 3.0-Slow it will be for a 1UZ-FE all aluminum V8 engine from an early 90's donor vehicle like a Lexus SC400 or Toyota Soarer or Crown. Torque is increased and HP will be 100 more than that of the 3.0L. From my investigation into this the R150F works quite well with this engine.
    getaway88, Moon Landing and SlvrSlug like this.
  8. Apr 15, 2021 at 2:53 PM
    mjamgb
    mjamgb New Member
    mike
    Son's Gen2
    None yet
    You can also consider various other V-6's. The Buick and Chebby units are OK. Heck, and OHC turbo 4 could work nicely too.
