Mud flap recomendation
Discussion in '5th Gen 4Runners (2010-2024)' started by zzchipster, Jan 2, 2024.
  1. Jan 2, 2024 at 8:31 AM
    zzchipster
    zzchipster [OP] New Member
    chip
    2024 4runner 4x4 4.0L ltd
    Brought home a new 2024 4runner limited on Dec 29th. This is my third and it did not come with the mudflaps. I was told the oem flaps don't fit, been told that several times. The mud flaps that come out of gulf states toyota are a propriety item. Any recommendations for after market mud flaps?
    Thanks
    Chip
  2. Jan 2, 2024 at 8:53 AM
    ^How much of the ugly side skirt and plastic cladding are you willing to remove?
  3. Jan 2, 2024 at 9:05 AM
    That’s a new one.
  4. Jan 2, 2024 at 9:14 AM
    zzchipster
    chip
    Would like bolt on.
  5. Jan 2, 2024 at 9:17 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    4FED6BF4-A257-4373-9FD3-CDE1D73170E4.jpgThis is what I did to add mudflaps to my 2011 Limited. Not a very straight forward modification. Parts were sourced from a couple of different year 4Runners.4FED6BF4-A257-4373-9FD3-CDE1D73170E4.jpg
    roooo and zzchipster[OP] like this.
  6. Jan 2, 2024 at 9:18 AM
    zzchipster
    chip
    My 2006 and 2016 4R Ltd came with flaps from gulf states toyota. This one I did not preference so I got what it had, no flaps.
  7. Jan 2, 2024 at 11:19 AM
    Trees91
    Trees91 .
    Forrest
    South Dakota
    2023 MGM SR5p
  8. Jan 2, 2024 at 11:29 AM
    So the Limited trim doesn’t come from the factory with mud flaps?
  9. Jan 2, 2024 at 12:37 PM
    zzchipster
    chip
    To get MF they have to be preferenced from Gulf States Toyoya, the importer. I usually do that, but this vehicle was already on the lot. Some come with MF and some don't. This one didn't. There is not a part number to order for the limited 4R. Seems
    Gulf States has a proprietary part. Don't know how that works if u wreck one.
    djwantke likes this.
  10. Jan 2, 2024 at 12:41 PM
    zzchipster
    chip
    I contacted rokblokz today, didn't list 2024. Haven't heard back yet.
    Also Weathertech doesn't have cargo mat available yet. Just front and rear seats. They are probably waiting for verification.
  11. Jan 2, 2024 at 12:56 PM
    shooter1231
    shooter1231 New Member
    2023 Mag Gray 4Runner Limited
    Did something change between the 2023 Limited and 2024? My local Toyota dealer (not the dealer I bought the vehicle from) installed the Toyota Mudguards (PT769-89110) and the Nightshade version of the Limited running boards (PT925-89190) about a week, or two, after I bought the vehicle. I didn't watch them being installed so I don't know if they had to do anything special to install them on a Limited - but I recall dropping the 4Runnner off before work and they called me to pick it up before lunch - so installation of the mudguards and running boards must have been pretty easy. The OEM mudguards look like they fit very well on my 2023 Limited. I've been driving the vehicle with the mudguards on for almost exactly a year - no problems with the Toyota mudguards.
  12. Jan 2, 2024 at 1:08 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Hey
    Making factory mudflaps work would be nice. But I found them ugly and insufficient. I did a mudflap delete, then replaced with aftermarket Husky Liners Kickback Mud Flaps. Custom install though, as in you mark existing fastener locations with clay, transfer marks to the flaps, drill and bolt on.
    Goodluck!
  13. Jan 2, 2024 at 11:32 PM
    you could say your car came... limited
    hahaha
    HuskerRunner and djwantke like this.
  14. Jan 2, 2024 at 11:46 PM
  15. Jan 2, 2024 at 11:58 PM
    zzchipster
    chip
    Which do I drive today?
    Harringbr99 likes this.
  16. Jan 3, 2024 at 5:37 AM
    Curlystooge
    Curlystooge Member
    Flyover
    2022 limited in magnetic grey
    I would drive the white one, but that is just me.
  17. Jan 4, 2024 at 11:03 AM
    switchman2
    switchman2 New Member
    George
    2023 4Runner
    Added running board
    I installed this set, its for Limited. Got it from toyota dealer.
    Mudguards
    Part Number: PT769-89110
    1 $88.50
  18. Jan 4, 2024 at 1:15 PM
    zzchipster
    chip
  19. Jan 6, 2024 at 10:19 AM
    bronzestar1
    bronzestar1 New Member
    2023 Limited magnetic gray with redwood interior
    275/55-20s, Airaid CAI, Summit muffler, oil catch can
    I have a '23 Limited, got these off Amazon. Rears went on without any issues, did have to drill the top hole on the fronts and use the supplied button-head screws. They're the perfect width for the 275/55s...
    A42 likes this.
  20. Jan 6, 2024 at 4:40 PM
    zzchipster
    chip
    Look good
  21. Jan 6, 2024 at 8:03 PM
    KENTUCKYRUNNER
    KENTUCKYRUNNER New Member
    2006 sport to a2016 SR5 PREMIUM TO A 22 LIMITED
    I had Toyota install mudguards on mine a week or two after i bought it because they were out of stock when i picked it up. They fit
  22. Jan 7, 2024 at 8:34 AM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    the white one with mud flaps.
