Mud flap delete
Discussion in '5th Gen 4Runners (2010-2024)' started by GreyRunner808, Jun 4, 2020.
  1. Jun 4, 2020 at 4:10 PM
    GreyRunner808
    GreyRunner808 [OP] In the process of build
    Big Island, Hawaii
    I have a couple questions for everyone. 1) What’s their experience, good or bad with removing your flaps?
    2) Besides buying the deletes from Revtek, Has anyone cut their flaps to make it look like you took them off? Because removing them completely, allows all that mud get stuck in that corner.
  2. Jun 4, 2020 at 4:31 PM
    GreyRunner808
    Big Island, Hawaii
    Awesome, thanks! I’m thinking about buying some tough hard vinyl and cutting them myself. I saw the Revtek covers but wanted to save $$
    it looks like if I just take them off and cut it down might be the option I’m leaning on, wanted to see if anyone actually did that with good results!
    7385 likes this.
  3. Jun 4, 2020 at 4:34 PM
    GreyRunner808
    Big Island, Hawaii
    Also forgot to mention my dog loves them! Lol
    Devil Run, Flit04, 2ndGen22re and 5 others like this.
  4. Jun 4, 2020 at 6:41 PM
    Daytonaviolet
    Daytonaviolet TRD Bro
    Bay Area, CA
    Blizzard Pearl TRD Bro
    I’ve seen folks outline the flaps with a marker. Then simply remove and cut them down with a strong pair of scissors or utility knife. Once installed, it will sit flush and contour the fenders.
    GreyRunner808[OP] likes this.
  5. Jun 4, 2020 at 8:15 PM
    kbp810
    kbp810 rebmem wen
    I’m usually a DIY kind of person, but I did the revteks this round. I wanted the option for going back if I ever find some sort of compelling reason to do so.
    The only real major mudflap pro (rears anyways); is if your lifted and have aggressive tires that are prone to picking up rocks, they can help prevent flinging rocks at the people driving behind you.
  6. Jun 5, 2020 at 6:20 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Hi Greyrunner808, here's a couple of photos of what I did after installing my Victory 4X4 Strike bumper. In Victory's installation videos, Darryl just removes the rear flaps and installs the bumper, but its pretty buttoned up back there when its stock, and where I live in a snow belt it's an area of the car that will fill up and pack in with sand, gravel, salt and mud. So, I trimmed the flaps and made up a splash pan that fits inside the frame of the bumper made of 1/16" aluminum checker plate. On the exhaust bracket side, I cut a notch for the hanger. I happened to have a couple of pieces of scrap metal that worked, but these can be purchased in metal shop fairly inexpensively. Its easy to cut and work with. You can see at the back, I cut a big drain hole. The middle screw uses an OEM bracket for the old plastic bumper cover and i drilled one additional hole for a body screw to hold them on. I plan to remove them at least once a year to pressure wash that area, maybe more often if I've been on a muddy trail.
    My front flaps are stock, but they're short and not in the way and do a good job of protecting the vehicle.
  7. Jun 5, 2020 at 9:15 AM
    GreyRunner808
    Big Island, Hawaii
    Thanks for the tips, looks awesome!
    Oldtoyotaguy likes this.
  8. Jun 5, 2020 at 10:25 AM
    Blue 4ever Runner
    Blue 4ever Runner New Member
    2019 Blue 4Runner
    I don't like the look of mud flaps so I removed mine. I trimmed the rears and used black silicone to fill in the gap around the outside. Not perfect but good enough for me.
  9. Jun 5, 2020 at 10:32 AM
    Oldtoyotaguy
    Hey Blue 4ever Runner, there’s no wrong way, it’s your vehicle, just do it! As long as it works for you, and I’m sure it looks great. The stock rear mud flaps in particular aren’t the best off road. First rule is to get rid of all the stuff that hangs down and flaps around before Mother Nature modifies it for you.
  10. Jun 5, 2020 at 2:04 PM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    TLCA #25089
    I trimmed the bottom section of the mudflaps since the extra bit looks like some weird engineering mishap.
    grizzlypath, DRobs, 7385 and 2 others like this.
  11. Jun 5, 2020 at 4:41 PM
    GreyRunner808
    Big Island, Hawaii
    I just did that too!
  12. Jun 5, 2020 at 4:44 PM
    GreyRunner808
    Big Island, Hawaii
    I also removed my running boards, I like that look better, although now my kids just gonna need help getting in! Lol
    Kfish, BilRite, toy33 and 2 others like this.
  13. Jun 5, 2020 at 6:43 PM
    Oldtoyotaguy
    4 Runners look great without running boards, imho. I find they trap mud, snow and salt and I end up with that dirt on my pant legs getting in and out.
  14. Jun 5, 2020 at 6:47 PM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    I love the clean look but would have destroyed my rocker panels several times already had it not been for my sliders.
  15. Jun 5, 2020 at 6:49 PM
    Oldtoyotaguy
    Definitely, sliders are completely different.
    BilRite likes this.
  16. May 28, 2021 at 5:31 PM
    Rock-N-Roll
    Rock-N-Roll TRD Amateur
    2021 T4R ORP w/ KDSS
    Silly question. I can find lots of info on removing the rear flaps including the revtek delete kit. What's the deal with the front flaps? Are people just trimming those because there is no other option?
    Runnerxp likes this.
  17. May 28, 2021 at 8:31 PM
    If it ain't broke, don't fix it.
    Stock mud flaps work for me.
  18. May 28, 2021 at 8:59 PM
    Rock-N-Roll
    I smashed up the flaps on my old FJ Cruiser which is why I'm asking. I suppose it depends on where you take your 4Runner. I'd would prefer to not have them on there based on the FJ experience.
  19. May 28, 2021 at 9:36 PM
    That's a good reason. Maybe consider OEM flaps that are trimmed a bit higher.
    I would think OEM flaps would fit better than aftermarket.
    A&P likes this.
  20. May 29, 2021 at 3:37 AM
    kbp810
    kbp810 rebmem wen
    The fronts just come off; they don’t leave big holes like rear ones do. You just simply remove them.
    djwantke and Rock-N-Roll[QUOTED] like this.
  21. May 29, 2021 at 9:15 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    I pulled the front ones off for clearance issues, I left the rear ones on because I try to be nice and not hurl rocks into people’s windshields on the highway.
  22. May 29, 2021 at 1:52 PM
    Rock-N-Roll
    Thanks for the confirmation!
  23. Jun 28, 2021 at 8:09 PM
    TRDawg
    TRDawg New Member
    2021 TRD Off Road Prem. XP Predator
    New 4Runner owner here.
    Has anyone installed the Revtek mudflap delete on a 20 or 21? Pretty sure they will fit but want to confirm.
    Thanks
  24. Jun 28, 2021 at 8:38 PM
    Rock-N-Roll
    I can confirm that they fit my 2021 ORP.
    CLopezNV likes this.
  25. Jun 28, 2021 at 8:44 PM
    TRDawg
    TRDawg New Member
    Thanks for the quick response, and the info!
    Rock-N-Roll likes this.
  26. Jun 29, 2021 at 10:57 AM
    DallasTRDPro
    DallasTRDPro New Member
    Dallas
    2021 Honda CRV...UGH!
    Yes they fit the '20
  27. Jun 29, 2021 at 11:14 AM
    TRDawg
    TRDawg New Member
    Thank you
  28. May 23, 2022 at 5:01 PM
    KillDozer4R
    KillDozer4R New Member
    2022 4Runner TRD OffRoad
    Anyone know if the revtek kit fits a 22’? Unlikely it changes but wanted to check just in case.
    cliffordsr5 likes this.
  29. Jan 3, 2024 at 1:30 PM
    raimieb
    raimie
    2021 ORP 4x4
    Lots…
    Any kits for a front mudflap delete? Trying to avoid the tire rub of 285s.
  30. Jan 3, 2024 at 2:42 PM
    It seems that if you remove the mudflap, but replace it with something else, there'd still be rubbing...
