**CLOSED**Mount Tray - Switch-Pros SP9100/SP8100 Power Module Vertical Mounting - Group Buy**
Discussion in 'Deals & Group Buys' started by ramonortiz55, Nov 26, 2019.
  1. Nov 26, 2019 at 10:14 AM
    ramonortiz55
    ramonortiz55 [OP] New Member
    Ramon
    CLOSED
    Switch Pros Mounting Trays - VERTICAL Mounting!
    Why is it important to keep Switch Pros Power Module mounted Vertical? Switch Pros instructions state to keep the module vertical to allow warranty to be in effect.
    Why ruin your investment?
    **AS OF THIS MOMENT, THIS TRAY IS ONLY AVAILABLE FOR 5TH GEN 4RUNNERS**
    Tray Only Options, for the do it "yourselfer":
    The Terminal Block Mount Tray - $100.00
    The Fuse Block Mount Tray - $100.00
    The Blank Mount Tray - $100.00
    Mount Tray Accessory Packages, for the "full shabang":
    The Terminal Block/Blue Sea Package Mount Tray $140.00 includes:
    Blue Sea Terminal Block 30A - 8 Circuit 2508
    Blue Sea Common 150A BusBar - 10 Gang with Cover 2300
    Ground Cable, BusBar to Battery, Black
    316 SS Mounting Hardware
    The Fuse Block/Blue Sea Package Mount Tray $245.00, for the "I'm going all out":
    Blue Sea ST Blade Fuse Block - 12 Circuits with Negative Bus and Cover 5026
    Ground Cable, BusBar to Fuse Block, Black
    Blue Sea 285-Series Circuit Breaker - Surface Mount 100A 7187
    Cable, Fuse Block to Circuit Breaker, Red
    Cable, Circuit Breaker to Battery, Red (16" or 24")
    Discount:
    We need 20 participants for $20 off
    If we reach 40, I will ask the vendor to see if we can get an additional discount!
    Shipping is USPS Priority $14.35 (Hawaii and Alaska included)
    Fine Print
    1. California Taxes apply for California residents.
    2. A participant is someone that places a Mount Tray order, regardless of any accessories or amount of accessories purchased. Accessory purchases without a Mount Tray do not qualify for a discount.
    3. Shipping to Canada (or any other place for that matter) is charged based upon actual cost of USPS Flat Rate Priority Box. For reference random Canadian 'TE' zip code, was just under $50.00. Any duties or taxes are the responsibility of the person its shipped to.
    4. Hawaii and Alaska are included with shipping as quoted above.
    5. Invoices will go out December 10th and need to be paid by end of day Friday December 13th. Packages will start shipping within a couple of days after its paid as long as stock holds out, after which there will be a 3 week backorder.
    If you are interested in this:
    Sign up by replying to this thread. Don’t chicken out. You are either in or you aren’t. NO maybe, no waiting on the wife, gf or bf to get permission. There is enough time to make up your mind or find a doctor to sell your kidney or pawn your wife’s jewelry. If you are on the fence to see if it’ll go up to max discount before you jump in, you are HOLDING the group buy back. Don’t be that dude.
  2. Nov 26, 2019 at 10:15 AM
    ramonortiz55
    Ramon
    List:
    1.
    2.
    3.
  3. Nov 26, 2019 at 11:02 AM
    Dillusion New Member
    KYle
    Where does this mount?
  4. Nov 26, 2019 at 11:57 AM
    ramonortiz55
    Ramon
    Here is an installed picture in this discussion thread.
    The wiring is a bit out of place, but it gives you an idea
  5. Nov 26, 2019 at 12:00 PM
    ramonortiz55
    Ramon
    Here is another one, courtesy of @tomb_rnr
  6. Nov 26, 2019 at 12:10 PM
    ramonortiz55
    Ramon
    Courtesy of @norcal556
  7. Dec 3, 2019 at 8:31 AM
    ramonortiz55
    Ramon
  8. Dec 3, 2019 at 8:36 AM
    KYle
    Looks neat but I prefer something covered.
