Morimoto XB fitment question
Discussion in 'Lighting' started by Taylor1234, Feb 8, 2022.
  1. Feb 8, 2022 at 12:12 PM
    Taylor1234
    Taylor1234 [OP] New Member
    Taylor
    2020 4runner
    I picked up the Morimoto XB gen 2 for a steal and put them on my 2020 ORP last night. Everything is working as expected and output vs stock halogen is night and day!
    I am, however, experiencing a problem with the fitment and am curious if anyone else ran into this and if so what they did to fix it. Unfortunately I did not notice until I put everything back together but the issue is the exact same on both sides of the vehicle.
    Basically the headlights appear to sit a quarter inch too low. There is also a spot where the paint from the car is starting to rub off although I believe this was actually caused by the OEM headlights and the area was just covered by the OEM lights so I never realized it. Attached are a few pics.
    Anyone else have this issue? Did I screw something up or are the tolerance for this light just a bit off?
  2. Feb 8, 2022 at 1:36 PM
    K-Paul
    Corbin Dallas
    SR5 4WD
    Cant speak for fitment issues, but if you are able to set the assembly a little differently you will want to touch up that spot as soon as possible to keep from rusting. (im sure you already know this, but life surprises me all the time lol.
  3. Feb 8, 2022 at 1:39 PM
    Taylor1234
    Taylor
    2020 4runner
    Don't worry - I have my touch up pen ready! I just need to find the time to take off the bumper again to mess around with this. Hoping someone can chime in with an easy solution.
    K-Paul[QUOTED] likes this.
  4. Feb 8, 2022 at 6:04 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
    I hope mine aren't going to be off like that. They arrived yesterday but won't be installed until Friday or Saturday.
  5. Feb 8, 2022 at 7:44 PM
    Taylor1234
    Taylor
    2020 4runner
    At the very least you will know to play around with the fitment before tightening everything back up. I was reading a discussion on another forum and someone had trouble with theirs and discovered the bracket you transfer from the OEM lights was not seated correctly. I'm wondering if that's my issue...
    Good luck on the install!
    BionicRandy likes this.
  6. Feb 8, 2022 at 7:47 PM
    spyder918
    spyder918 501st Unit: GGG
    2019 TRD ORP MGM
    Yep mine are like that as well. My tails are like that too. Hard to find parts that will be as close/tight as OEM when it comes to head/tail lights. I don't have the corner rubbing off and your Mori's shouldn't cause that either.
  7. Feb 8, 2022 at 7:50 PM
    Taylor1234
    Taylor
    2020 4runner
    Bummer. Guess I'll get over it because the lights otherwise work great and look amazing.
  8. Feb 8, 2022 at 7:52 PM
    spyder918
    2019 TRD ORP MGM
    Yeah trust me, I'm pretty ocd and it doesn't even bother me anymore esp b/c I love the lights so much.
  9. Feb 9, 2022 at 7:45 AM
    2020 4Runner
    Fl
    Yeah the brackets could be an issue if it's the same on both sides. I had the XBs on my 2013 Tundra and the fitment was off. The XBs on my 2020 Tundra are a perfect fit. I'll install hers this weekend. If I have any issues and come up with a fix, I'll let you guys know. I was aircraft and jet engine maintenance for 24 years, so I have alot of mechanical background.
  10. Feb 9, 2022 at 9:31 AM
    Taylor1234
    Taylor
    2020 4runner
    Much appreciated!
  11. Feb 12, 2022 at 1:57 PM
    2020 4Runner
    Fl
    Installed. 1st pic is stock headlight on driver's side. 2nd is XB on passenger side.
  12. Feb 12, 2022 at 3:19 PM
    Taylor1234
    Taylor
    2020 4runner
    Overall looks pretty comparable. Did you run into any issues? Any paint rubbing off in the corners?
    I love those in amber! I snagged the white but those look slick!
  13. Feb 12, 2022 at 6:07 PM
    2020 4Runner
    Fl
    The passenger side had a mark when I pulled it out. No issues with installation at all.
  14. Mar 15, 2022 at 10:16 AM
    onaquest
    onaquest New Member
    After following this thread, I'm now seeing the fitment gap in pretty much all product shots for these lights.
    Would it possible be to use some washers to raise the housings up to lessen the fitment gap?
  15. Mar 15, 2022 at 10:25 AM
    Taylor1234
    Taylor
    2020 4runner
    I would like to see if someone tries this. I am not going to take my bumper off for a while but if I ever do ill give it a try and report back. Based on how the brackets fit I'm not fully convinced that will work but it would be worth trying. I'm just living with it for right now.
    onaquest[QUOTED] likes this.
  16. Mar 15, 2022 at 4:04 PM
    spyder918
    2019 TRD ORP MGM
    Any of you guys had any issues popping the corners of the bumper back in? I'm referring to just below the far outer edge of the headlight. Driver's side is fine but my passenger side just stays popped out..so annoying.
  17. Mar 15, 2022 at 4:17 PM
    Taylor1234
    Taylor
    2020 4runner
    I did with my passenger side too - it took some playing around with to seat it back properly and has since actually popped back out again slightly. For me it's small enough that I just ignore it but I've seen a few people have this issue. I'm not sure if it's the lights or if the bumper just doesn't like to go back together...
  18. Mar 15, 2022 at 4:34 PM
    onaquest
    onaquest New Member
    Is your 4Runner a Limited trim? I've read it's somewhat common for the Limited bumper skins to pop off the retaining clips in the area below the headlights
  19. Mar 15, 2022 at 4:35 PM
    Taylor1234
    Taylor
    2020 4runner
    It's not - 2020 ORP
  20. Mar 15, 2022 at 4:48 PM
    onaquest
    onaquest New Member
    the only other that comes to mind would be the order of reassembly. did you push the bumper skin back onto the clips before fastening the wheel arch bolts?
  21. Mar 15, 2022 at 4:50 PM
    Taylor1234
    Taylor
    2020 4runner
    Honestly I don't recall but I wouldn't be surprised if I did that incorrectly.
  22. Mar 15, 2022 at 4:51 PM
    spyder918
    2019 TRD ORP MGM
    Mine is an '19 ORP. Yeah I tried all kinds of things and orders. It may have something to do with the grill because when I line up the holes for the grill, then the corner pops out again...weird and frustrating.
