Morimoto G2 headlights on a 2020 - fuse box cover won't fit now
Discussion in '5th Gen 4Runners (2010-2024)' started by anomaly24601, Dec 13, 2020.
  1. Dec 13, 2020 at 11:08 AM
    anomaly24601
    anomaly24601 [OP] New Member
    Hi guys,
    i scoured the interwebs and can't find anything on this....I just installed the G2 headlights from Morimoto....they work perfectly, BUT since the fuse box in my 2020 seems to be different from the install videos I found of other 5th gens, the damned box won't close up now....the fuse tap sticks up too much....
    anyone have this issue and what did you do to fix it? keep in mind i'm mechanically declined and this headlight install took longer than it should have with lots of cussing....
    i'd rather not cut a hole into the fuse box and try to tape up the hole as a friend suggested....
    any help would be greatly appreciated :)
    stunner_4runner likes this.
  2. Dec 13, 2020 at 11:39 AM
    stunner_4runner
    stunner_4runner New Member
    Raymond
    2020 4Runner SR5 4WD
    Radflo Stage 3 Lift Kit- 2.5 Extended Front & Rear RR Adjustable Coilovers Total Chaos Upper Arms ARB rear medium springs 3” Aiden James Switchback Fog Bezel Lights 4Runner Lifestyle Amber Raptor Grill Lights Trail Standard Offroad Satin/Matte Black TSO Pro Grille with 4Runner Letters Baja Designs WC Amber Fog Lights Baja Designs XL Sport Amber Ditch Lights with Cali Raised Ditch Light Brackets 2 Baja Designs LP6 Amber Behind the grille lights 2 SNS Designs 5" Amber Behind the grille lights N-FAB behind the grill lighting mount Pedal commander Jet Performance Mass Flo Air Sensor 315/70/17 Cooper STT Pro Fuel Rims Custom Magnaflow exhaust with Series 50 Flowmaster Muffler Alpharex Nova Midnight Black Headlights AFE Momentum GT Dry Filter CAI BantamX Touchscreen for Universal with sPOD Alpharex PRO-Series LED Tail Lights Jet Black Mid-Atlantic Off-Roading Full Length Roof Rack Outgear Solutions Low Key Front Bumper 4WDKING 30’ LED Light Bar for the Bumper RSG Front Skid Plate
    Hey,
    Ughh sorry that your fuse box lid won’t shut. I read some reviews about other people having the same problem as you. The only other recommendation I was reading was to put a hole in your fuse box lid so the fuse tap can fit. But like you stated “Why in the hell would you want to do that?”
    This is one of the reasons why I decided to go with the AlphaRex Nova Headlights.
    Hopefully someone knows a solution to your problem. Sorry!!
    gunsnob likes this.
  3. Dec 13, 2020 at 12:49 PM
    anomaly24601
    yeah i was afraid i might have to go that route :(
    thanks for the reply....
  4. Dec 13, 2020 at 1:04 PM
    ruiz4251
    George
    TEXAS
    16 Trail Premium
    NOOOOOO! Use a heat gun! Gently heat about where the fuse will touch then press the top on
  5. Dec 13, 2020 at 1:13 PM
    4scooter19
    4scooter19 New Member
    Oregon
    98 and 86 4Runners
    stunner_4runner and ruiz4251 like this.
  6. Dec 13, 2020 at 1:20 PM
    anomaly24601
    hahaha this is a great idea...with my luck i'll accidentally melt through the plastic lol....
    this is a great find! it says at the bottom i can email them with my updated fuse box info and so maybe they can fab one for me.....
    i'm going to email them and if they can't fab one, i'm going the heat gun route.... thank you guys!
  7. Dec 13, 2020 at 5:06 PM
    ForRun
    ForRun 4Runner
    2020 orp
    Well, I can tell you what not to do! Only because I did and cost me time, money and a rig with no ignition for two days.
    1st I bought these mini fuse taps and they work fine... except when you remove them! It tore out my fuse block.
    Replaced that and found these low profile fuses with a wire built in! Lucky me I tried it in the old fuse block 1st and damn thing didn't fit.
    I ended up with a manual switch in the cab but you can also tap the ignition fuse in the driver's footwell
  8. Dec 13, 2020 at 5:14 PM
    ForRun
    ForRun 4Runner
    2020 orp
    That's for the fuse block by the steering column in the cab. If you tap the inside ignition fuse you should use that cover. On the other forum someone posted a file or link so you could 3D print your own.
  9. Dec 13, 2020 at 5:31 PM
    4scooter19
    Oregon
    98 and 86 4Runners
    I don't own a 5th gen, just thought it might help him out. Sounds the like meso might be able to make custom ones. Wonder if they could make an under the hood one?
    ForRun[QUOTED] likes this.
  10. Dec 13, 2020 at 5:37 PM
    ForRun
    ForRun 4Runner
    2020 orp
    That would be awesome! I just found the whole thing odd that Toyota puts the one fuse most everyone needs to tap in a place that you can't
    4scooter19[QUOTED] likes this.
  11. Dec 14, 2020 at 6:45 AM
    anomaly24601
    well thanks for this heads up...usually people end up learning form my mistakes lol...
  12. Dec 14, 2020 at 6:52 AM
    anomaly24601
    well i emailed them to see if they could do this since i don't have a 3d printer....i'll post back when they get back to me....
  13. Dec 14, 2020 at 11:33 AM
    anomaly24601
    just got a reply from the company.......aaaannnnd they said they won't make one for the engine bay.... looks like it's heat gun time....
    thanks again to everyone
  14. Dec 14, 2020 at 12:15 PM
    mtnbiker67
    mtnbiker67 New Member
    Scott
    2020 TRD
    Okay, don't cut a hole in your cover! I had same issue. #1, make sure you swap out the 3amp fuse with a 10amp. The 3 amp will just keep blowing. #2 just plug it into the heated mirror fuse like on previous model. Everything will work fine and you won't have to alter your cover. The only reason they put it into ignition fuse is because with version 2, that was the only place they could get the Bugatti style start up to work when ignition starts. To me, that didn't matter since I can't see it anyway from driver seat.
    ForRun likes this.
  15. Dec 14, 2020 at 2:02 PM
    anomaly24601
    sweet! i'll give this a shot....i think i can live without the fancy startup light show for the same reason as you....thank you!
    so you haven't had any issues since using the mirror heater spot then?
  16. Dec 14, 2020 at 2:07 PM
    mtnbiker67
    Scott
    2020 TRD
    None at all. Works great.
  17. Dec 14, 2020 at 2:12 PM
    mtnbiker67
    Scott
    2020 TRD
    Also, careful which direction you plug the the fuse tap in. The fuse puller on bottom of cover will hit the tap and not close properly. You'll see when doing it. Simple.
  18. Dec 14, 2020 at 2:40 PM
    anomaly24601
    thank you!
    and thanks again to everyone who chimed in!
  19. Dec 16, 2020 at 8:24 AM
    smeerun
    smeerun New Member
    2016 MGM TEP w/KDSS
  20. Dec 16, 2020 at 9:14 AM
    ForRun
    ForRun 4Runner
    2020 orp
    Alpharex ships those with the lights and they do not fit under the cover. For whatever reason they redesigned the 2020 fuse box
  21. Dec 16, 2020 at 10:08 AM
    smeerun
    smeerun New Member
    2016 MGM TEP w/KDSS
    They ship the one OP is using or the shorter one I linked? At any rate, I think what you're saying is that the fuse box cover on the 2020's doesn't have room for an add-a-fuse at all?
  22. Dec 17, 2020 at 7:32 AM
    anomaly24601
    i believe the one Morimoto ships is the larger one.... and what you ask is partially correct....the fuse tap fits if it's moved to another section of the fuse box.....if you look at my pic where it's plugged in, the section is raised higher than the rest of the fuse box and that's the issue....
    but after plugging it into the mirror heater plug in the lower section as mtnbiker67 suggested, everything is working just fine (minus the fancy startup light show that neither of us care about since we can't see the lights from the driver's seat)
  23. Dec 17, 2020 at 12:50 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    There are two types of fuse tsps people are using. One is a mini-tap, the other is a low profile mini-tap (LP-mini). It looks like you used the mini, which sits a little higher than the low profile version. The LP-mini would work better.
  24. Dec 18, 2020 at 9:41 AM
    anomaly24601
    thanks for the input...this pic is a good reference for future projects too....
  25. Mar 7, 2021 at 9:33 AM
    HouTx4Run
    HouTx4Run New Member
    David
    2021 4Runner TRD Pro Lunar Rock
    I found this thread after googling around with the same issue after installing raptor lights and using the engine compartment ENG fuse location (unable to fully close the lid) - what was your solution? Did you use the heat gun to re-shape the lid? Curious - I can sort of close the lid but it's not fully secure. I have the 2021 TRD Pro Lunar Rock 4Runner.
  26. Jul 16, 2021 at 5:59 PM
    4RFanatic
    4RFanatic New Member
    Southern California (what is rust?)
    2021 4Runner TRD Pro Magnetic Grey
    AlphaRex, Morimoto, Dynamic Diode, Lasfit, Rockford Fosgate, iDatalink Maestro, Metra, Kicker, Kenwood, Infinity, Dirt King
    Hi all. I have the same fuse cover issue. Alpharex recommends using the INJ fuse to tap into. I would rather not modify that fuse box. I will run a 16AWG wire into the inside fuse box and tap into the IGN No.3 fuse. It's switched. I'll test which side of the fuse power comes from and orient my tap in the correct direction. The Alpharex Nova series DRL power comes with a low profile fuse tap and a 5A fuse. If you see anything wrong with this solution please let me know. If you know what the IGN No. 3 fuse is used for specifically, please let me know or send a link. I can't find any information on it. I'll update with results or issues. Thanks for this thread and all the input.
  27. Jul 17, 2021 at 12:39 AM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    With a multimeter you can map out the fuse functions of the engine fuse box and cabin fuse box. But to be confident you need some reliable documentation. Maybe someone here can provide it, but you can also get it yourself.
    If you’re doing any electrical additions or modifications to your 4Runner you really need to be sure of what you’re tapping into.
    I’d suggest you get a 2-day subscription to the Toyota Technical Information System (TIS) for $20. You can browse around and you can download the pertinent wiring diagrams, repair info, and other tech info for your model year so you have a reference library for this and any other electrical mods you may do in the future. It can take a while to do all the downloads manually.
    https://techinfo.toyota.com/techInf...chForm%2FsearchDocument&_pageLabel=t3_page_66
    LeeTN likes this.
  28. Jul 19, 2021 at 9:55 AM
    4RFanatic
    Thanks for the tip ElectroBoy! That's worth it to me.
    ElectroBoy likes this.
