Moonroof problems… help
Discussion in '5th Gen 4Runners (2010-2024)' started by Roger88, Aug 29, 2023.
  1. Aug 29, 2023 at 2:52 PM
    Roger88
    Roger88 [OP] New Member
    2015 4Runner
    sorry if there’s already a thread on this
    Help! I cannot get my moonroof to do anything. I’ve tried to reset it, it clicks but will not do anything. I’ve even unhooked the battery and then tried to reset the it again by holding down the tilt up and tilt down multiple times. I just took it in for a recall and asked the dealership to look into it, they told me it has to happen at the time they are looking at it. They said it worked fine on the test drive so they did not run a diagnostic test. Of course, right? But I can’t get it to tilt or open at all.
  2. Aug 29, 2023 at 5:50 PM
    OdyRunner
    OdyRunner New Member
    Does it do it all the time or intermittently? If its intermittently I would just drive it down there while its having the problem and have a service rep/technician come out and look at it. Don't take no or "you have to schedule an appointment" as an excuse and make them come out and look at it. If its under warranty, I have ran into more than a few dealerships who will say its operating fine, that they couldn't duplicate the issue, etc... only to pick it up, have it not work as designed, and had to force them to come out and try it in front of me before they would admit it was in fact inoperable.
  3. Aug 29, 2023 at 6:20 PM
    HuskyMike
    HuskyMike New Member
    Take it back to the dealer and have them show you that it works.
    Roger88[OP] likes this.
  4. Aug 29, 2023 at 7:49 PM
    Roger88
    2015 4Runner
    It only does it intermittently, the problem started since I changed the battery out several months ago.
  5. Aug 29, 2023 at 7:51 PM
    Might be a stupid question (I don't have a moonroof), but is there a specific fuse for this? I didn't see that mentioned.
  6. Aug 30, 2023 at 3:27 AM
    HotelMedicis
    HotelMedicis No Commercial Interests
    I had this happen on my Land Cruiser and it turned out to be the switch itself. I pulled it out, fiddled with it and put it back in making sure that the connections were tight and the moonroof worked fine after that. Just a thought.
  7. Aug 30, 2023 at 6:06 AM
    Daddykool
    Have you tried disconnecting the battery for about 30 minutes? Something might have flaked out when you replaced it.
  8. Aug 30, 2023 at 8:33 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Switches and sensors are always the first things I suspect. In any kind of device, switches seem to fail before anything else.
