Misfire at 2800 RPMs
Discussion in '3rd Gen 4Runners (1996-2002)' started by desertdan, Feb 28, 2019.
  1. Feb 28, 2019 at 7:05 AM
    desertdan
    desertdan [OP] New Member
    1999 4 runner
    stock
    on cylinder 3&6 i have swaped coils with other one but still same problem plugs are new and swiched wiresalso with no change any help would be apprecated
  2. Feb 28, 2019 at 7:15 AM
    rhinolined
    rhinolined New Member
    Andrew
    1991 4Runner 3VZ-E 4x4 5-Speed
    sounds like it has to do with timing, do you have a timing gun because sometimes when the timing is off it will idle but once you increase the RPMs it gets worse and could be the cause of the misfire
    Bob likes this.
  3. Feb 28, 2019 at 7:44 AM
    desertdan
    1999 4 runner
    stock
    thankyou for your respomse no dont have timing gun but will get one if that is a possible fix but i think it might be something diff cause runns smoth till get ti bout 2800 rpms and then stumbles alil code reader p0300 p0303 p0306 but only when i go 60 mph or in 2nd about 2800 rpms
  4. Feb 28, 2019 at 1:18 PM
    HoBoDanny
    HoBoDanny Dude...
    Daniel
    Kentucky
    2004 SR5 V6 4WD 4Runner
    Possibly a air flow problem intake or exhaust. Could also check fuel filter and injectors.
  5. Feb 28, 2019 at 7:27 PM
    rhinolined
    Andrew
    yea i didnt realize it was a 99 when i responded (guess i should pay attention to the year) not sure if a timing gun will work as i dont think the 99 has a distributor for timing, pretty sure its electronic timing.
  6. Mar 1, 2019 at 4:41 AM
    Jsbcarman
    Jsbcarman New Member
    1996 limited
    What kind of parts did ya use, Toyota's like denso parts, the AutoZone crap not so much , and did you replace coil(s) or just switch cylinders , your post stated "other one" so not sure if that means swapped cylinders to see if miss followed coil or if it or they are new.
  7. Mar 3, 2019 at 2:00 AM
    desertdan
    1999 4 runner
    stock
    THANKS AGAIN I HAVE DENSO PLUGS sorry for caps and all a did was swich coils on cylinders but still reads 3 and 6 cylinder missfire
    runs real smooth til i hit 70 mph in drive or stomp on it for passing then it stumbles and check eng lite flashes or if im in 2nd and accelerate it will stumble at low speed was wondering if throtle sensor could be faulty
  8. Mar 3, 2019 at 8:06 PM
    Jsbcarman
    1996 limited
    Put new coils and wires on it ,should fix it , boss just did same thing on his 01 4runner for similar issue
  9. Mar 26, 2019 at 12:04 PM
    desertdan
    1999 4 runner
    stock
    so after many attempts at curing my check engine lght changing my fuel filter did the trick hope this helps someone
    the lack of fuel caused the miss fire butit still has stumbling at high rpms
    Jsbcarman likes this.
  10. Mar 26, 2019 at 12:58 PM
    aroyalsfan
    aroyalsfan The Owner
    Kansas City
    Have you checked the gaps on your plugs? Somewhere between .041-.043.
  11. Mar 26, 2019 at 2:34 PM
    Think it was sabatoge? Or did you soak the engine bay down when you washed it??
