Min lift for 285/70/17?
Discussion in '5th Gen 4Runners (2010-2024)' started by Moran_miguel, Dec 8, 2018.
  1. Dec 8, 2018 at 9:05 AM
    Moran_miguel
    Moran_miguel [OP] New Member
    Northern California
    2018 T4R TRD off road premium
    Boss performance suspension system with upgraded rear springs and 3” lift/level; BFG K02’s 285/17/70; TRD Pro Wheels; Cat Black Performance Exhaust
    Just purchased 2018 T4RDOR premium. I would like to upgrade to 285/70/17 BFGK02’s on TRD pro rims. What is the minimum lift to accomplish this. Thinking 2.5” spacers front and 1” rear. Will this work?
    Strandskov likes this.
  2. Dec 8, 2018 at 10:06 AM
    4X4Runner
    The left coast
    Well, 285’s can be run but are not recommended on TRD Pro rims due to the 7” width vs. 7.5 on the TRD OR rims.
    You’d need 2.5-3” up front and even then, there possibility of rubbing.
    Any reason for spacer as opposed to say, a bilstein suspension lift?
  3. Dec 8, 2018 at 10:42 AM
    Rguest3
    Rguest3 2018 TRD Off-Road Premium
    Lakewood Ranch. FL
    The stock springs are VERY soft with a lot of Squat upon Acceleration and Nose Dive when braking. The Spacer Lift will only exagerate this even more.
    As Stated, the Bilstein 6112 Front Coil-Overs (5160 Rear Shocks) with 2" Rear Springs would be a great Lift and a great ride. You would enjoy this much more.
    saltlife1966 and Strandskov like this.
  4. Dec 8, 2018 at 12:02 PM
    Crossfit4Runner
    Crossfit4Runner New Member
    Saint Louis
    2018 TRD Off Road Permium
    To many to list
    I’m running 285’s on TRD Pro wheel with a 3” lift with no issues so far. My shop says they do it all the time with no issues. They were doing another 4Runner when I was their picking mine up.
  5. Dec 8, 2018 at 1:21 PM
    Jaywall
    Jaywall 2018 4runner premium
    Jay
    Cottontown, Tn
    2018 SR5 premium
    3in Toytec lift, uca's, 20 in Ion wheels wrapped in 275-60-20 amp A/T pro
    I have a 3 in lift with 275-60-20 which is a 33.1 x10.8 x20 with a 0 offset rim and i have a slight rub on the back of the inner fender at full lock reverse
    Trd361 and (deleted member) like this.
  6. Dec 8, 2018 at 2:35 PM
    Moran_miguel
    Northern California
    Ok my bad. Forgot to mention that I have KDSS. Does that change anything? Agree that stock suspension is a bit squishy but I was hoping for the least intrusive option that also kept the value of KDSS intact.
  7. Dec 8, 2018 at 2:51 PM
    4X4Runner
    The left coast
    I’m lifted 3” with an OME lift on a KDSS equipped 4R and it did not affect the KDSS
    Strandskov and Moran_miguel[OP] like this.
  8. Dec 10, 2018 at 10:55 PM
    Moran_miguel
    Northern California
    So feeling good about going with:
    BFG KO2s 275/79/17 and jumping to the Bilstein 6112 Front Coil-Overs (5160 Rear Shocks) with 2" Rear Springs upgrade.
    BUT any thoughts or recommendations on the rear springs since I will be towing small travel trailer. And sometimes small ski boat. Would you recommend an upgrade to the rear shock or stay with this? Thank you in advance!
  9. Dec 11, 2018 at 1:14 PM
    Pertaining to your original question, there are people running 285's at stock height without major rubbing issues. You're most likely to rub due to the width of the wheel and/or the offset than you are with height clearance issues. I will be putting 285's on my 4Runner soon with a 1.6" lift in the front and 0" in the rear. I'll be running Trail wheels (17" x 7.5") with a 0 offset. TRD wheels are even skinnier.
  10. Dec 12, 2018 at 9:52 AM
    rkwfxd
    rkwfxd New Member
    Rich
    Whittier - So Cal
    You might consider adding air bags to the springs. Deflate for daily driving and then inflate when you are going to tow.
    jgcaps and Strandskov like this.
  11. Dec 14, 2018 at 8:38 AM
    Sparkkky
    Sparkkky New Member
    2018 4 Runner TRD Off-road
    Eiback Pro lift, ARB Summit bumper, Smitty Bilt wench, Summit flood LED
    Eiback truck Pro lift, you won't believe the handling and ride improvement, springs and great shocks, very affordable.
    Strandskov and nimby like this.
  12. Dec 14, 2018 at 1:09 PM
    Narbeh
    Narbeh New Member
    Narbeh
    La Canada Flintridge
    2019 4Runner TRD Off Road Premium
    Hey man I’m going to be doing the same. Can you measure how tall your truck is now. What’s the max height from the floor to the highest point on the factory roof rack rail? Is it less than 77inches???
  13. Dec 14, 2018 at 5:11 PM
    Crossfit4Runner
    Saint Louis
    To many to list
    Best I could tell as I didn’t have help mine looks like 75-76 inches.
  14. Dec 14, 2018 at 5:13 PM
    Narbeh
    Narbeh New Member
    Narbeh
    Cool. I think I should be ok then. Considering 275s to save a little in height and keep overall unsprung weight down.
  15. Dec 17, 2018 at 12:45 PM
    Crossfit4Runner
    Saint Louis
    To many to list
    *****Update*****
    I was having some rubbing issues when backing up every once and awhile so my shop did some front fender mods. They shaved the inside and moved the molding.
  16. Dec 18, 2018 at 2:03 PM
    Crusifix
    Crusifix New Member
    2015 TRD Pro (Inferno)
    3.5 lift all around. King in the front OME in the rear.. Other stuff..ya know, 4runner stuff...
    TRDP here, but I am lifted to the equivalent of 3.5" on a standard t4r. 285/70/17's on the stock TRDP wheels and 1.25" F / 1.50" rear spacers. No rubbing at all, in any condition or environment. I also do not have the front sway bar installed, so I see an extreme amount of articulation. Even with that, no rubbing.
  17. Dec 18, 2018 at 2:33 PM
    Narbeh
    Narbeh New Member
    Narbeh
    my parts are being installed tomorrow. will report back. Thanks for the info buddy.
    Strandskov and Crusifix[QUOTED] like this.
  18. Dec 18, 2018 at 7:18 PM
    Daohaus
    Daohaus New Member
    Duan
    Eastvale CA
    2018 Black ORP 4Runner
    Rotiform SIX-OR | Toyo Open Country RT 285/70/17
    I fit the tire stuffing on stock suspension and only had to do front fender liner mod and trimmed my factory mud flaps (I wanted to retain those) went camping with it in September in Bishop has to drive 22 miles of Offroad switchbacks with ruts and sketchy stuff and it handled it perfectly no rubbing.
    I'm now lifted 2.5" on Bilstein and love it
    SlvrSlug and Crusifix like this.
  19. Dec 25, 2018 at 6:54 PM
    browndirtcowboy
    browndirtcowboy New Member
    king 3" lift kit, fuel vectors, 285 toyo mt's, oem audio 500q, morimoto hid headlights, morimoto led fogs,
    What my man said ^^^
    Even with a 3" lift I still needed a cab mount chop, to eliminate any rubbing for offroad. But tires make a difference as well. Toyo MT's have the highest tread therefore new meats will rub at full turn in reverse.
    jgcaps and Crossfit4Runner like this.
