Milestar all terrian pro?
Discussion in 'Wheels & Tires' started by hossler1788, Sep 16, 2025 at 1:47 PM.
  1. Sep 16, 2025 at 1:47 PM
    hossler1788
    hossler1788 [OP] Turtle
    Joshua
    Central Pa
    2020 4runner
    Is there anyone running milestar at pro tires on here?
    I know the milestar mud terrain are a high recommended tire. And these all terrains look pretty awesome. Also the 285 75 17 is very lightweight for a e rated 18/32 3 ply sidewall tire(52 lbs).
  2. Sep 16, 2025 at 6:26 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Jan. 2024: custom installed 2lb fire extinguisher between drivers seat and door -Feb. 2024: swapped interior lighting to diode dynamics led’s -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting -Feb. 13/2024: double ditch lights, on new Rago Fabrication Extension brackets. -3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Existing: 3inch EVERGEAR clear lens LED pods -May 2024: custom black aluminum grille mesh installed in front of factory plastic -June 2024: custom built powder coated dom sliders -Nov. 2024: thermo-plastic rear mudflaps -Dec. 2024: rear bumper cover clearance cut, sprayed newly exposed parts black -Jan. 2025: trailer hitch removal, relocation of rear led pods to crossmember New: -Exhaust pipe chop after axle -March 2025: new SPC upper control arms, bushings, balljoints. Raised front end 0.75” via Bilstein 5100 spring seat. -April 2025: Evergear bezel-less cube ditch lights 4 LEDs 40W 3.33A 4800Lm 328’ beam distance 30° 6000k beam angle shatter & crack resistant lens -April 2025: Evergear Ultra Series light bar 27-3/4” flood spot combo 60 LEDs 60W 5A 6000Lm 1227’ beam distance Dual row, dual beam angle 30°/60° April 2025: BULLY Rock Crawler Hi-Intensity LED Utility Lights, Pair 1260 lumens @ 15w (3 x 5w CREE) each 120° flood beam waterproof, dustproof. Under hood: -Blue Fire 6-Circuit Fuse Block w/ LED Indicator & Protection Cover -Blue Sea 100A Circuit Breaker w/ reset lever In progress/in the garage queue: ~ Wanted - 80% OFFROAD Hitch Replacement Recovery Point, PerryParts or Wheelers bump stops, 1" body lift, custom dom front bumper, winch, rear dom bumper with side hoops, kdss angle correction, C or D load 35’s, bolt on cat shields
    Watching thread.
    Thanks for this, I’ve seen these around on some big rigs.
    I really dig the couple non-E load options, SL 285/70 in particular. All tires larger appear to be E load, trying to avoid E if I go bigger..285 do look phat on my 9” rims tho.
    hossler1788[OP] likes this.
  3. Sep 17, 2025 at 5:29 AM
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    285 75 17 are definitely my next tire size. But im looking for lighter weight options and these came up on discount tire listed at 52lbs. And appear to be aggressive enough for my offroad adventures
    CygnusX-4 likes this.
  4. Sep 17, 2025 at 5:41 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Milestar makes some excellent tires from what I hear. Plus, 285/75/17 is a solid option a ton of people seem to overlook.
    That said, I'll likely swap the 285/75/17 Falkens for some D load 35x12.5 Baja Boss AT's. Not much heavier, only .6" taller, and should ride smoother than my current E load range (and heavy) Falkens.
    I have a buddy that just did this and it makes me very jealous...
    35" Baja Boss AT
    0 Offset + spidertrax spacers
    and for reference here's mine on 34" (285/75/17) Falken AT4W. -36 offset.
    ChessGuy likes this.
  5. Sep 17, 2025 at 7:54 AM
    Those tires look pretty nice. How’s the actual price? The pricing seems all over the place online?
  6. Sep 17, 2025 at 8:35 AM
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    Walmart has them 2857517 for $250ea
  7. Sep 17, 2025 at 8:38 AM
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    Id love to get 35s. I was actually looking at the 315/70/17 goodyear territory mts c rated and 55lbs.
    What do your 285 75 17 falken measure(od) on the 4r?
  8. Sep 17, 2025 at 9:08 AM
    I guess that’s a good deal these days.
  9. Sep 17, 2025 at 9:59 AM
    CygnusX-4
    CygnusX-4 Member
    CO
    21 TRD OR
    That weight is impressive for the size, and 3peak rating-nice! My Toyo RT trails are 63lbs each (285 75 17 Es). It's funny, I always shunned the E loads, but have been pleasantly surprised with the Toyos. With the regear I did, and Dobinsons suspension, it drives way better than it did stock. Looking forward to your review!
  10. Sep 17, 2025 at 10:38 AM
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    Post some pictures of your 4r
  11. Sep 17, 2025 at 11:45 AM
    Is that right, dang, and mts means M/T tread tho..?
    My 285/70 E loads are 55lbs!
  12. Sep 17, 2025 at 11:57 AM
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    No its like a rt tread design
  13. Sep 17, 2025 at 12:13 PM
    “All terrains” or no?
  14. Sep 17, 2025 at 1:17 PM
    hossler1788
    Joshua
    Central Pa
    2020 4runner
    Its a mix between all and mud terrains
    djwantke[QUOTED] likes this.
  15. Sep 17, 2025 at 1:44 PM
    1SilverRunner
    Tejas
    They are a true 34" tire which is why I got them. But they are very heavy and make me wish I would have just went with 35's in the first place.
    Only things that keeps me from swapping are
    1. Good tires are expensive
    2. .3" of sidewall ain't much at all...
    But they do look damn good and according to my buddy perform very well.
  16. Sep 17, 2025 at 2:06 PM
    Thanks!
