Mice
Discussion in '5th Gen 4Runners (2010-2024)' started by Jynarik, Apr 19, 2024.
  1. Apr 19, 2024 at 7:40 AM
    Jynarik
    Jynarik [OP] I like boobies
    Austin Texas
    2019 trd pro voodoo
    DAMNIT! Had all my lights flashing on dash (4lo, brake, etc). And found a mouse nest in the cabin air filter.
    I’m not an electrical guy. Where do I start?
  2. Apr 19, 2024 at 8:20 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid (modified) RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Lasfit LED Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Electrical isn't my thing but I'd guess take a volt meter to the fuse box and see if anything is getting intermittent power. That should give you a starting point.
  3. Apr 19, 2024 at 8:24 AM
    Deep scan for codes which will require a dealer visit. You could look around for damage such as under the intake manifold like what happened to mine.
  4. Apr 19, 2024 at 8:26 AM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    Remove the engine cover and look at all the exposed wiring. You'll probably find chewed up loom and some chewed wires. My father's Camry had been dinner for a mouse, and he had the dealer fix it... For 500 bucks! They spliced wires back together, wrapped the splices in electric tape, and did nothing to the loom. Butt connectors and heat shrink tubing will work well if you can find the damage.
  5. Apr 19, 2024 at 8:32 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    mrmike7189 likes this.
  6. Apr 19, 2024 at 8:40 AM
    Fuel injector wiring. Mine was damaged in the same place before the 2 year mark. Insurance covered the repair to the tune of $9K because Toyota would only do a full engine harness replacement because of the vehicle age.
  7. Apr 19, 2024 at 8:42 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    are you kidding me??
  8. Apr 19, 2024 at 8:44 AM
    It can be repaired but the since my Runner was so new at the time, they didn't want to simply repair. Comprehensive insurance will cover it though.
    I'll find pics of mine.
  9. Apr 19, 2024 at 8:47 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    well fuck. Taking to local shop now. What did you do to keep mice away?
  10. Apr 19, 2024 at 8:52 AM
    I removed the engine cover and spray Grandpa Gus's peppermint oil after washing the engine. I haven't had issues again. (knocks on head dad joke)
    Someone competent can simply replace the injector pigtails.
    What I saw:
    Dealer pics:
  11. Apr 19, 2024 at 8:54 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Nasty mfers. I found a plastic package of brake pad pins, a rubber glove, and other random shit they brought into cabin air.
    Thanks for the help. Crossing fingers it’s not an expensive fix.
  12. Apr 19, 2024 at 9:02 AM
    This is what I use. Since it say " Rodent Repellent Spray for Vehicle Engines and Interiors ", I thought it's much safer than home made stuff. Just in case I spray when the engine is cold and won't start for few hours, pretty much wait overnight.
    https://amzn.to/3xJrrYs
    You might have seen my video on few other points. Maybe dumb but that's what I do.
  13. Apr 19, 2024 at 9:10 AM
    Looks like it's going to the fuel injector. Easy repair with a $10 pigtail and a couple of crimp & seal butt connectors: https://www.rockauto.com/en/moreinfo.php?pk=7988068&cc=3307198&pt=2577&jsn=417
    You should take a closer look to see if any other wires under the intake manifold have been chewed. The knock sensor is a favorite item for mice and happens to use the same connector.
  14. Apr 20, 2024 at 7:22 AM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    The real screwed up part about this is, car manufacturers have switched to using soy based wire sheathing instead of petroleum, presumably for environmental reasons. There should be a class action lawsuit given the number of expensive rodent related issues that have occured. It is rediculous that one's 50k dollar investment can be so easily damaged.
    Skywarner, mrmike7189 and 2Toys like this.
  15. Apr 20, 2024 at 3:48 PM
    legend1011
    legend1011 New Member
    great, another thing for me to worry about
    We do get mice in our garage from time to time
  16. Apr 20, 2024 at 5:09 PM
    That's an urban legend. Mice chew on stuff to maintain their teeth, otherwise their teeth keep growing like a cat's nails. Mice don't care if they're chewing through PVC, polyolefin, silicone, whatever. Hell, before they even reach the wire insulation, they chew through the split loom, which is most definitely plastic. This also means mice will chew on airplane wiring. Keep that in mind the next time you go on vacation.
  17. Apr 20, 2024 at 5:21 PM
    I’m pretty sure mice are on the protected species list here in Calif. so be careful.
    LCJ77, Kad2112, jgalt and 2 others like this.
  18. Apr 20, 2024 at 5:23 PM
    Was it a "Deer Mouse" cause those are so freakin cute.
    Seriously i would soder not use crimps.
  19. Apr 20, 2024 at 5:24 PM
    I think the kangaroo mice are adorable.
  20. Apr 20, 2024 at 5:24 PM
    Ill just put a bag on snake poop in the engine compartment?
  21. Apr 20, 2024 at 5:25 PM
    Lay the skins, I get those every couple months.
  22. Apr 20, 2024 at 6:51 PM
    SVMTRCSR
    SVMTRCSR New Member
    318 curves in 11 miles
    2021 4Runner SR5 2WD
    Go Trump!
  23. Apr 20, 2024 at 7:03 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    I use to think that way but there are really nice crimps now with a heat shrinkable jacket which seals them up very nice and avoids the flex/embrittlement that solder can do.
    I was in the trenches in the R&D field for almost 35yrs and I resisted doing crimps and usually soldered/shrinked but the shrinkable style crimps are really nice. The shrink kinda acts like a strain relief as well.
  24. Apr 20, 2024 at 7:34 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    Repel All from Home Depot. Spray the hell out of the engine bay.
  25. Apr 20, 2024 at 7:54 PM
    2ndGen22re
    CR
    Carson Valley, NV
    How does it smell?
  26. Apr 20, 2024 at 7:56 PM
    Yotaholic
    Olympia, WA
    Like crap.
  27. Apr 22, 2024 at 11:48 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    So here’s a little update:
    the wire I found chewed was not throwing a code, but the wheel sensor was. This was recommended to be the issue with the codes I had on the dash, but finding the wire under the hood I didn’t bother looking at it.
    the weird part is, I don’t see how a rat would have made such a clean cut on this wire, but who knows. IMG_4804.jpg
  28. Apr 22, 2024 at 4:12 PM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    I had a mouse nest under my hood insulation blanket....had to remove the blanket. Little m'fkers chewed a hole in the blanket and jumped up into it. Now I spray "mighty mint" all over the engine bay every few weeks as a little mouse insurance. :D It seems to work
    2Toys, Jynarik[OP] and wing2 like this.
  29. Apr 23, 2024 at 7:18 AM
    jgalt
    jgalt New Member
    I use peppermint oil applied to a PSA felt pad, placed on the battery. Easy, clean, and hopefully effective. The whole engine compartment smells like a candy cane lol.
  30. May 17, 2024 at 9:54 AM
    Jynarik
    Austin Texas
    2019 trd pro voodoo
    Man, this shit is getting old.
    Wife calls me to tell me she was pulling out of garage to find a CEL, traction light, and something else on. I’m at work so can’t look at it.
    I’ve continued to find droppings in my cabin filter, but only after driving so figured it was residual. peppermint oil spraying on the regular. Haven’t seen a rat in probably 2wks.
    Nervous to look at it when I get home tomorrow. This is becoming an expensive headache.
    2Toys, SlvrSlug and mrmike7189 like this.
